Randal
Dec 1 2006, 05:46 PM
Is there one available for a 2.0 (4)? And do they just bolt in, or do you have to change pulleys or what.
THANK YOU
Aaron Cox
Dec 2 2006, 12:50 AM
not that i know of....
you could adapt a GM unit.... (see it done at STF)
Mueller
Dec 2 2006, 12:59 AM
here you go...doubt they bolt right up...less than $300
Liteweight alternators....QUOTE
AL-9101-A
35 amp, 5.6 lbs.,
One Wire Alternator
AL-9101-B
45 amp, 6.0 lbs.,
One Wire Alternator
AL-9101-C
65 amp, 9.0lbs.,
One Wire Alternator
AL-9101-D
120 amp, 12.8 lbs.,
One Wire Alternator
When mine died last year at Hershey, I ended up buying another in Washington DC (actually this was Alexandria, VA) at a place valled "Arlington Armature". I expected a rebuilt stock unit but I got one that is differrent- It had an Aluminum or alloy case/ frame, 65 amp output, and a one year warrenty. Prolly 20% lighter than the one I took out. I don't know if they would always have this type,but they might have something... I haven't googled them, but they are out there I know, at least by phone if not interweb.
Cap'n Krusty
Dec 2 2006, 06:20 PM
The OE units have an alloy case. It's the innards that are heavy. The Cap'n
Randal
Dec 2 2006, 06:34 PM
QUOTE(Mueller @ Dec 1 2006, 10:59 PM)
AL-9101-A
35 amp, 5.6 lbs.,
One Wire Alternator
AL-9101-B
45 amp, 6.0 lbs.,
One Wire Alternator
AL-9101-C
65 amp, 9.0lbs.,
One Wire Alternator
AL-9101-D
120 amp, 12.8 lbs.,
One Wire Alternator
I'm going to call them on Monday. Thanks Mike.
Joe Ricard
Dec 3 2006, 07:02 AM
Jeg's has a small unit. 90% chance of having to modify something.
