jr91472
Dec 2 2006, 01:00 PM
Getting ready to put in my new clutch and flywheel. I have all the necessary parts (seals, felt washer, etc).
My rear main seal is only one year old and does not leak at all. Do I need to replace it since I am replacing the flywheel?
I only ask as I had difficulty getting the RMS to seal properly last winter and ended up doing it a couple of times. Would rather not go through that again.
thanks
Allan
Dec 2 2006, 01:03 PM
If it aint broke......
Aaron Cox
Dec 2 2006, 01:18 PM
or while your in there LOL
i would leave it if it is 1 year old
jr91472
Dec 2 2006, 01:21 PM
I like the way you boys think....
TheCabinetmaker
Dec 2 2006, 01:28 PM
JR, If it doesn't have oil on it when you pull the flywheel, leave it alone!!!!!!!
Curt
So.Cal.914
Dec 2 2006, 01:33 PM
I have changed my flywheel a few times, once because the face was fuched up
and had been resurfaced one to many times and once to put a lightened fly
in it. The original had a grove worn in it where the seal rides on the flywheel.
New part new seal. It is cheap insurance. And replace the pilot bearing also,
and the throw out bearing if it needs it.
Cap'n Krusty
Dec 2 2006, 01:47 PM
If you're replacing the flywheel, you MUST check the endplay, and adjust if necessary. The Cap'n
TheCabinetmaker
Dec 2 2006, 01:53 PM
QUOTE(Cap'n Krusty @ Dec 2 2006, 01:47 PM)
the Capn is right. My bad.
