Your telling me he has no rust in the longs? Are we looking at the same pics?
Click to view attachmentFerg
You're looking at pan rust. The longs were given a clean bill of health.
Paul...step in here if things have changed.
Ferg and Pat,
We are all on the same page, so to speak. The previous picture shows a thoroughly rusted portion of the rear pan, rust is confined to that portion of the pan, and a whole pan replacement will not be done. The longs on both sides have been deemed solid. As there has been no degradation of door closure nor top fitment issues, coupled with the pictures I've been e-mailed, the determination that the longs don't need replacement is welcome. The new pieces being welded in are being treated on the inside surfaces prior to installation for corrosion resistance and
after fitment, a rust inhibitor is to be applied into the cavity.
A little background info on this car. Back in 1978, I trailered this car to the same shop because the right rear trailing arm mounting point failed, due no doubt to the car's early exposure to salt filled roads in the winter and the rigors of several AX seasons. At that time, the longs were intact and a rust inhibitor applied to their yellow painted surface. That is the black material that you can see in some of the pictures. Subsequent to the aforementioned repair in '78, the car has not been on winter roads. Back in 1978, this shop was the only one familiar with this console failure, as no one in Cincinnati had any idea how to fix this. Furthermore, this shop was the only one near me at the time that had the proper frame alignment equipment to affect the repair properly. In the intervening years, I've had no issues with alignment even with subsequent AX seasons. So my previous experience with this body shop warrants my belief and trust in their advice and judgement.
