the problem....
had engine out to work on some battery tray rust. removed the fuel pump to paint hell hole and battery tray. i replaced all the fuel lines. put everything back and hooked up. turning over but not firing. pull the lines to the fuel rails and i am not getting any fuel. messed around with the connection at the fuel pump and snapped off the wiring. went to splice a new connection and after checked and i have 0 volts comming from the positive lead to the fuel pump.
things that i have checked......
1. fuel pump is good-runs when hard wired from battery.....
2. next step is to go to the main power relay and check voltage at pin 87 and then 86. i did this and i get 0 volts at pin 87....
i get 12v at pin 30 on all of my relays but at 87 nothing. what does this mean? i have been looking over the schematics and i am kind of stuck.
do i dig into the relay board and start trouble shooting those connections or do i go somewher else? did I forget to plug something in? i have had the engine out plenty of times and have never had a problem.
are there any electrical guru's out there that have delt with pin 87.....????
thanks,
craig
