So I've got my car up on jackstands like a proper 914 should be right now. Yesterday I finally had time to look into why the oil filters keep blowing out.
Click here to catch up
So I've got out my trusty Hayne's manual, looking for the oil pressure relief valves. The one that is in the oil filter mount moves freely. I can tell the spring is still intact. So I look at this diagram:
The manual doesn't have what I would consider very good pictures of the check valves. I can find the one at the oil filter, but where is the one at the oil pressure sender? I suspect that might be the culprit I am looking for. Do I need to remove the cooling shrouds?
Thanks!!
