Full Version: Will this portable electric compressor be suitable for performing leak
Mid_Engine_914
I bought this 3-gallon compressor a couple of months ago - will it be suitable for performing leak-down tests "in the field" using this leakdown tester from Eastwood? The compressor produces a maximum of 100 psi.
SGB
You are set. Thats a cool little compressor. I just did one (compression test) recently using a compressor that was twin 2 gal cylinders and I never came close to running out of air.
Mid_Engine_914
Great. That little compressor's turning out to pretty useful.
LvSteveH
Actually, a 12V car compressor and a 6 gallon portable tank would do the trick in a pinch. My 12V compressor is good to 240psi and the tank is good to 125psi. You typically want to run leakdown at 100psi because it's easy to get the results in percentage, ie 94 psi = 94%
