QUOTE(Dr Evil @ Dec 6 2006, 12:44 AM)
I can adjust it in 5min by placing the tranny in 3rd with the stick if you can, loosening the pinch bolt, move the stick to where it is touching the spring plate and it is where you will want 3rd to be in the future, tighten the pinch bolt.
Clear as mud? Maybe I will do a photo piece on this over my winter break.
My problem was that the shift rod simply did not want to turn, no matter how much you loosen the pinch bolt. I did not have a suitable needle nose vise grip to apply enough torque. Ended up unbolting the shifter from the tunnel so I could pull it off the rod completely and insert it again to gain a different positioning.
Once I was done I noticed that the actual change of position was minuscule compared to the scratch marks I had made to mark the position before disassembly. This was to remedy a situation where the idle position as provided by the spring mechanism ended up on the 4/5 gate instead of 2/3 after welding the broken tunnel shift rod back together again.
Haven't had it on the road yet for a real test, keep your fingers crossed
