everything *between* the yellow lines is the bottom of your long !!!!
everything inside the red lines shows the bottom of the hell hole ...
everything inside the green lines is your floorpan ...
like i said before, that round tube you see is the metal part of the heater tube that
runs inside the long if the longs were OK, you shouldn't be able to see inside ... makes sense?
Andy
PS: this *is* fixable, but it's not an easy repair. you will HAVE TO support the chassis correctly to keep it within specs before you weld this up. your chassis is already flexing and out of spec as it is. the two longs are the spine that holds your car together. if one is weakend like that, your car *is* flexing ...
