solex
Dec 9 2006, 03:51 PM
So I just got some steel wheels and tires 205/50 Falkens and installed them today, they look great (Thanks Jerry), I will post some pictures soon.
I did not really check tire clearance until I took a quick ride around the block and noticed the smell of rubber. The passenger side rear is rubbing on the inside fender well, the drivers side is perfect. What are my options, is there any adjustment that can be made?
Dan
porschecb
Dec 9 2006, 04:01 PM
Just bend up the inner lip and or roll the fenders
Joe Bob
Dec 9 2006, 04:08 PM
Baseball bat and roll the fenders....do a search and the full proceedure will come up.
solex
Dec 9 2006, 04:18 PM
Unfortunately it is not the outer fender well where the tire is rubbing it is the inside. The back of the tire is rubbing.... can I put on one spacer?
TheCabinetmaker
Dec 9 2006, 04:46 PM
not sure, but i would think that you have to space all four wheels.
Spoke
Dec 9 2006, 05:21 PM
Sorry to hear of the clearance issue. I had them on both the red and green cars. The only thing I could think about was checking the toe in the rear and hopefully this wheel needs to come out some.
Spoke
steveinOC
Dec 9 2006, 05:24 PM
Nothing wrong with spacers when you need them.
But I would check the trailing arm bushings and make sure that
is not the cause of the inner wheel well rub.
So.Cal.914
Dec 9 2006, 05:37 PM
QUOTE(steveinOC @ Dec 9 2006, 03:24 PM)
It could also be a weak spring, are they original?
Also a failing trailing arm connection point can cause it to sag.
Mueller
Dec 9 2006, 05:57 PM
QUOTE(solex @ Dec 9 2006, 01:51 PM)
Dan
rubbing on the inside it pretty odd...something sounds bent or damaged or you have some odd offset rims..
GeorgeRud
Dec 9 2006, 06:20 PM
Certainly check the springs and alignment, but a set of 1/4 inch spacers may make all the difference. Tires may be marked the same, but do not always have the same dimensions. Don't be afraid to experiment, but be sure you have adequate lug nut engagement with the spacers..
solex
Dec 10 2006, 12:21 PM
As promised the pictures are attached. I'm really happy with the way these tires/rims look.
solex
Dec 10 2006, 12:23 PM
Another side
solex
Dec 10 2006, 12:24 PM
the problem side, any quick things I can do to determine if the bushings or springs are bad?
solex
Dec 10 2006, 12:25 PM
problem side outer
Joe Bob
Dec 10 2006, 12:26 PM
Everything looks new. When was the last alignment?
solex
Dec 10 2006, 12:27 PM
Good side inner and outter
solex
Dec 10 2006, 12:29 PM
QUOTE(mikez @ Dec 10 2006, 01:26 PM)
Shocks are new, I believe that the springs are originals, the car is really solid in the rear. I'm not sure when the last alignment was done (probably never).
Is there anything I can do temporarily to move the tire out a little before I do an alignment, how would I do it?
Thanks
Joe Bob
Dec 10 2006, 12:38 PM
Spacer....but then you may need longer lug bolts....
solex
Dec 10 2006, 04:53 PM
Update: I was able to loosen the bolts on the trailing arm support. I moved the tire by hand and now I have 1/4" of clearance, took it out for a spin and no rubbing.
I will work on getting the car aligned...
Dan
Joe Bob
Dec 10 2006, 04:55 PM
Probably the best answer....
Now finding a shop that can do it w/o buggering it up.....
