swood
Nov 16 2003, 01:15 AM
This'll be short, because I've attempted to post and it keeps nuking me when I submit.
Third item from the left does not seem to fit in this equation, but I've kept them together since disassembly. Where does it go?
Qarl
Nov 16 2003, 01:21 AM
Y=x^2+1x-7
swood
Nov 16 2003, 01:25 AM
that's not helping Qarl!
J P Stein
Nov 16 2003, 01:26 AM
Ah......between the 2nd & 4th. I love a good mystery
J P Stein
Nov 16 2003, 01:29 AM
Are you trying to post a pic, Steve?
Qarl
Nov 16 2003, 01:33 AM
We'd llike to provide real help, but we don't know what you're talking about.
Try making sure your pics are around 800x600 or 640x480. Make sure it is a .jpg or a .gif
File size should be less than 300k (or there abouts)
swood
Nov 16 2003, 01:34 AM
Yes JP. It'll turn out to be real stupid though. I'm putting my oil seal, impeller hub, locking plate, washer and bolt together and I have an "extra" part that I can't figure out where to put. It's a circular tube if you will that's about 7/8" in diam and 5/16" long, split longitudinaly. Just doesn't seem to fit in there.
I'll try posting again. Very frustrating, it's just a 150kb image...
J P Stein
Nov 16 2003, 01:36 AM
....and when you are ready, hit "add reply" NOT "preview post"
swood
again. Just don't tell me it goes on the inside of the case!!!
J P Stein
Nov 16 2003, 01:38 AM
Sorry, I dunno dick bout 4poopers....cept they sound like tractors
HAY, we need a t-4 wonk in here!!
swood
Nov 16 2003, 01:34 PM
Bummer. Any other takers? I don't want to cross post.
THis is for the '75 1911
Mark Henry
Nov 16 2003, 02:26 PM
Ummm... that thing goes in the other end of the crankshaft.
It's a spacer to hold the pilot bearing out in the flywheel.
swood
Nov 16 2003, 02:34 PM
are you kidding me? I'lllook it up then.
Mark Henry
Nov 16 2003, 02:45 PM
It's no shit, Sherlock!
swood
Nov 16 2003, 02:53 PM
Uhh...I guess your attempting humor?
I just dont see it diagramed clearly anywhere. It looks though like it may go in the fly end of the crank under the #1 Main? Am I getting warm?
Nov 16 2003, 02:56 PM
oh boy, don't you hate it when that happens???
can't help you with that part tho ...
Andy
Brad Roberts
Nov 16 2003, 03:18 PM
Relax. It goes in the end of the crank. You can install it at any time BEFORE the flywheel goes on.
B
swood
Nov 16 2003, 03:20 PM
Ahh..B...The voice of reason. THanks dude.
I get to pull the fly off again though. Practice makes perfect right?
Brad Roberts
Nov 16 2003, 03:21 PM
Most machine shops dont pull them out.. I'm surprised you have it in hand.
Hopefully you didnt torque down the flywheel.
B
swood
Nov 16 2003, 03:23 PM
why? i did. Just didn't know I was missing something.
Brad Roberts
Nov 16 2003, 03:25 PM
It's not real good to reuse the lock plate after torquing the flywheel bolts down to it. I should'NT say this in public... but flip it over when you go back together.
B
swood
Nov 16 2003, 03:27 PM
now that i think about it, I was wondering what kept the pilot bearing from moving around. Now I know.
Brad Roberts
Nov 16 2003, 03:29 PM
Did you also install the felt washer when you installed the lock plate ??
B
swood
Nov 16 2003, 03:30 PM
sho' nuff
Mark Henry
Nov 16 2003, 05:42 PM
T’was a lame attempt at humour.
Why doesn’t anyone believe me, I only build/machine engines for a living.
A lot of good machinists take every little thing apart, it's the only way to clean things 100%.
J P Stein
Nov 16 2003, 07:28 PM
QUOTE(Mark Henry @ Nov 16 2003, 03:42 PM)
Maybe because you're a Canadian, eh?
I won't go on the the whores & hockey players thang.
Mark Henry
Nov 16 2003, 08:15 PM
QUOTE(J P Stein @ Nov 16 2003, 05:28 PM)
whores & hockey players !!!
That joke is as old as... well... JP!
