Crazyhippy
Dec 31 2006, 08:03 PM
got my new wrx motor installed and running last night, and started tweaking the computer to compensate for the increase in air flow... right as the motor gets to temp (fans had kicked on @ 186, and cooled the coolant down to 176) something comes loose @ idle, and before i can get to the key through the passenger window....
Crazyhippy
Dec 31 2006, 08:05 PM
this cant be good....
BMITCHELL
Dec 31 2006, 08:10 PM
That sucks!
Better to happen now and not tomorrow on the canyon roads.
Aaron Cox
Dec 31 2006, 08:14 PM
mongo not like!
McMark
Dec 31 2006, 08:17 PM
OUCH!!!! That sucks.
Good practice though?
Crazyhippy
I did get to drive it... made it about a mile, said, ok, need to go tune, and came home, it broke in the garage....
Glad this year is over, hope next is better, will drop the motor tommorrow AM, go meet the driving crew for a picnic, and then spend the evening throwing snowballs @ Kim.
BJH
Twystd1
Dec 31 2006, 08:46 PM
How about you fix the engine and I throw snow balls at Kim?????
Seriously bro,
I wish you the best of new years and a fixed engine.
Cheers,
Clayton
TravisNeff
Dec 31 2006, 08:49 PM
BJ, That is rough!
What would cause that, incorrect cam belt adjustment?
Crazyhippy
Dec 31 2006, 08:58 PM
timing couldn't do that... unless i broke the head off a valve
I'm guessing foreign matter into the motor somehow, but wont know till it's tore apart.
BJH
messix
Dec 31 2006, 09:32 PM
CHOPSTICK!
Crazyhippy
Dec 31 2006, 09:34 PM
it might be a
chopstick....Motor was designed in Japan after all....
Damn sneaky bastards
BJH
rick 918-S
Dec 31 2006, 10:16 PM
Dude! That looks bad!
Ferg
Dec 31 2006, 11:45 PM
Wow, that sucks.
Better new year to you!
Ferg
Joe Bob
Jan 1 2007, 12:32 AM
Bummer....wanna come up and help me get the Turbo running?
Eddie Williams
Jan 1 2007, 01:39 AM
QUOTE(mikez @ Jan 1 2007, 12:32 AM)
you can't turbo a 914!
dougcoup
Jan 1 2007, 08:03 AM
QUOTE(Crazyhippy @ Dec 31 2006, 06:03 PM)
I had something similar happen to my 2.0 4 cyl 914 engine. It turned out to just be a crappy cheap spark plug that went back and cracked, but then the plug arched to the head and welded its self
Hey on another note how tough was it to drop in the suburu engine?
Twystd1
Jan 1 2007, 09:00 AM
I think sumpin broke........
I B smart... I figured that all out by myself..
I wish i was there to help BJ.....
Let us know what transpires.
Clayton
elwood-914
Jan 1 2007, 10:46 AM
All your pulley marks line up......timing belt slip?
Me sorry. Is it a JDM engine?
GeorgeRud
Jan 1 2007, 06:14 PM
Is the Subaru engine an interference design (ie the valves will hit the pistons if the timing belt breaks and the cams go out of time)? It would suck to have to tear one of those down and haved to deal with all that water!
BMartin914
Jan 1 2007, 06:17 PM
QUOTE(GeorgeRud @ Jan 1 2007, 05:14 PM)
A lot of Subaru engines are not 'interference' engines.
MecGen
Jan 1 2007, 09:17 PM
Sorry to hear about it...
If I understand correctly
The valve should hit before the plug gets pounded...I wonder why a forien object took so long to make its way in ?
I had alternator bearings fall into a cyl (don't ask) once. The results were bad
fast. I would also check your fuel maps and timing at the time you were tuning. I doubt it caused the breakdown, but would realy suck if it happened again while tuning it.
Good luck Bro
Later
Elliot Cannon
Jan 1 2007, 10:23 PM
German car + Japanese engine can only lead to very bad Ju Ju. It's a curse. You need to find a Buddhist Priest to excorcise the demons within the machine or it will never run properly.
Aaron Cox
Jan 1 2007, 10:24 PM
QUOTE(Elliot Cannon** @ Jan 1 2007, 08:23 PM)
or have slits take a dump down the turbo....
KaptKaos
Jan 2 2007, 08:25 AM
cantley914
Jan 2 2007, 08:42 AM
[/quote]
The valve should hit before the plug gets pounded[/quote]
Even off timing it never reaches the plug.
Something had to break at the conecting rod.
Broken wrist pin?
WRX914
Jan 2 2007, 12:30 PM
Damn dude!
I hope you get things ironed out. Knock on wood, the only problem I have is a small coolant leak. Mike J is gunna tackle that one for me in a few days...
Still need a new turbo though, do you got one?
Wilson
Crazyhippy
Jan 2 2007, 02:29 PM
2, but if you're gonna replace it go bigger...
16G, bigger injectors, and back to crawford. good for 50 more HP at least...
Bring on the z06's!!!!
BJH
SLITS
Jan 2 2007, 04:50 PM
QUOTE(Crazyhippy @ Jan 2 2007, 12:29 PM)
BJH
Well, since you're hanging out with the Uncharted Island Group, guess I'll have to post it here....
1.) BJ25 Short block
2.) EJ25 Long block
TonyAKAVW
Jan 2 2007, 06:19 PM
BJ: I see flares and wider tires in your future.
-Tony
Crazyhippy
Jan 2 2007, 06:25 PM
QUOTE(SLITS @ Jan 2 2007, 02:50 PM)
BJH
2.) EJ25 Long block
Were either the shortblock or the longblock turbo originally? if not the compression is too high.
BJH
SLITS
Jan 2 2007, 06:34 PM
QUOTE(Crazyhippy @ Jan 2 2007, 04:25 PM)
BJH
2.) EJ25 Long block
BJH
BJ...... that is a question I do not know. BJ25 pistons are flat top..... don't know if I can see the ones in the EJ25.
Crazyhippy
Jan 2 2007, 08:38 PM
Any idea what they came out of?
I can find no info on a BJ25??
alpha434
Jan 2 2007, 10:53 PM
[quote name='cantley914' date='Jan 2 2007, 09:42 AM' post='841264']
[/quote]
Broken wrist pin?
[/quote]
Intake lift doesn't need to be very high with boosted engines. Might take a little while for something to break the valves first.
Crazyhippy
Jan 15 2007, 05:32 PM
After taking a bit of frustration time off, i have returned to this mess, dropped the motor this am, and this greeted me when i pulled the cam cover off....
One of these things is not like the others....
Crazyhippy
Jan 15 2007, 05:34 PM
So off comes the intake, exhaust, and Head....
Anyone need an exhaust valve for an 03 WRX? Make you a GREAT deal on the parts i can find
Crazyhippy
Jan 15 2007, 05:36 PM
Maybe you need a head (minus most of 1 exhaust valve)
TonyAKAVW
Jan 15 2007, 05:37 PM
ack! That doesn't look good. Time to buy yet another engine?
Crazyhippy
Jan 15 2007, 05:38 PM
Last pic.... Good news is it didn't hurt the cyl walls, i have another factory piston, and a head....
So.Cal.914
Jan 15 2007, 05:42 PM
Bummer.
Crazyhippy
Jan 15 2007, 05:43 PM
QUOTE(TonyAKAVW @ Jan 15 2007, 03:37 PM)
I should be able to re-build this one, tear it down, quick pass w/ ball hone, and double check the cyls, new bearings, rings and good to go...I already have a Known good head, and 3 good spare pistons.
Have to go buy a 14MM Allen wrench to get the wrist pin out now....
messix
Jan 15 2007, 05:44 PM
i would take a good look at the rod and the crank b4 firing that thing up again.
get them checked cracks and for being bent. [betcha the rods bent!]
Crazyhippy
Jan 15 2007, 05:49 PM
It let go @ idle, but i will check...
Aaron Cox
Jan 15 2007, 05:52 PM
barf....
its the aircooled gods wrath!
Crazyhippy
Jan 15 2007, 06:00 PM
making me run on 3 cyl to even things up??
Brando
Jan 16 2007, 12:09 AM
Dayum BJ... you are havin luck with Subi engines like I have luck with 924s and 944s.
I think you've spent almost enough in subaru repairs as some have in /6 conversions. That's almost ironic, if it weren't so bad
PS, I'm looking for a good boat anchor, so if you got a spare junk block
Crazyhippy
Jan 16 2007, 12:13 AM
I'm not into motors over 3K yet...
2K for the 1st one, 400 for the 2nd, gaskets, oil pump, waterpump, timing belt etc...
I dont see -6 motors running for 3K very often, and never over 300HP for that $
BJH
