QUOTE(michel richard @ Jan 2 2007, 09:19 AM)
Very slick.
They're steel, right ? Can you post dimensions ?
Yes, steel. I made some drawing changes on-the-fly, so some updates are required. Unless you have a 6 speed Audi/Getrag and late 911 axles, the dimensions are of little use as these are made for a completely custom setup.
The thickness was dictated by the space available resulting from some custom made trailing arms that moved the hub/bearing outboard by 1.20". Mounting face to mounting face distance is 1.125".
Andys
