spunone
Jan 9 2007, 06:27 PM
Looking for some good metric and standard Fastner
assortments anybody happen to buy these sets or do ya just go to the hardware store and buy bags of Chinas Best ? Thanks
dr914@autoatlanta.com
Jan 9 2007, 06:28 PM
QUOTE(spunone @ Jan 9 2007, 04:27 PM)
wurth. That is where we get ours.
slothness
Jan 9 2007, 06:30 PM
If I need something unusual I go to Parkers Nuts and bolts in Palmdale on Palmdale Blv, if its a common metric or std but a high grade its Lowes (or Home Depot) if its whatever then its all about Harbor Freight!
Aaron Cox
Jan 9 2007, 06:31 PM
mcfadden dale...
just go buy a couple boxes of 100 of everything...
pretty cheap by the box. way cheaper than home depot etc
TROJANMAN
Jan 9 2007, 06:44 PM
what do you need them for?
i just parted out a car and saved most of them
let me know.............
spunone
Jan 9 2007, 06:51 PM
Don't know what I need yet .it's when you need a bolt and nut and don't want to run out to the hardware store ?/ Thanks for all the replys and no Aaron I don't want to start a Hardware store LOL
cooltimes
Jan 9 2007, 07:13 PM
Bolts, nuts and info. Charts and conversions.
American standard, Metric and all others too.
Recommend as a bookmark whether you buy there or not.
http://mdmetric.com/home3.htmCooley
sww914
Jan 9 2007, 07:20 PM
You don't need that much stuff to be pretty prepared for a 914. Most of the car is 6mm X 1mm and 8mm x 1.25mm, the standard thread pitches. I have 3 lengths of 8mm bolts, 4 lengths of 6mm bolts, flat washers, wave washers, lock washers, nylocs and standard nuts of each size, 2 lengths of 6mm phillips head screws, some VW fan shroud style screws, a couple of types of trim screws. All of this stuff I bought in boxes of 100, mostly it was 3-5 bucks a box. I also keep a bit of 10mm stuff, a similar assortment as above, but only 25 at a time. I got it from Wurth and from the local nut & bolt route driver dude. If you call a couple of shops they'll tell you who the nut & bolt guy is, mine will come to my house if I'm buying more than $20.00 worth of stuff.
Also, I keep a pretty good assortment of wire and terminals, 100 at a time for the common stuff, 25 at a time for the wierder stuff.
Also, If I do have to go to the hardware store, if I need 2 I buy 6 or 8.
Bartlett 914
Jan 9 2007, 07:21 PM
Metric and Multistandard Components (google to get the url)
Mscdirect.com
McMasterCarr.com
The first one has without doubt the best selection. Many hard to find fasteners.
I always buy in box quanity when I can.
