Hi there,
I finally bought myself a 914 after wanting one since high school.
My dad has had a 1970 914-6 since 1972 and i've always wanted one.
Any way I bought a 76 2.0 for about $1400 on new years day, and I love this little car!
It has a small amount of rust, but I plan to treat it soon, Overall it is a solid car.
But I need help!
When I bought it i noticed that the car idled excesively high. I started tinkering around with the engine bay when i got home and noticed that what i believe to be the fuel pressure regulator? (fist sized component with a four wire connector and a vacuum hose-near battery) Adjusting the small screw in it was the only way i could get the car to idle normally (800 or so rpm).
Unfortunately is made the car hard to start once it warms up. I also played with the adjustment screw on the throttle body. But i haven't been able to get the car to idle correctly and run correcly at normal speeds, I suspect an air leak any sugestions would be appreciated!
