QUOTE(r_towle @ Jan 10 2007, 11:06 AM)
DO THIS FIRST!!!
It might make the kid happy, and it may be just the normal ride height that is gets reset to.
Also, look at the coil spring "upgrade" is will take out all the air compressor stuff, might be a better and cheaper long term solution for someone with not so much money.
Rich
The procedure for using the jumpers will get the compressor to run and allow the air springs to fill as you manually select them via the jumpers. The EAS computer and ride selection buttons will still show a fault and be inoperable.
My take is that the coil spring "upgrade" is more of a downgrade unless you have specific use requirements that make the EAS undesireable. For example, if you are doing remote severe wheeling and are far from civilization, then it might make sense. They have already bought a new compressor, so the only other items that might need attention are the air springs and valve block. I redid the entire valve block with new o-rings for ten bucks. This part new used to be north of $1,300 from the dealer. It takes some time to do the refirb, but it will last a long time once done. The other items, namely the air springs, only have two issues to deal with. One is the o-rings, which are cheap. The second issue being the bladder, which can be obtained from Arnott Industries for less than $100 per bladder...with a lifetime guarantee (either the truck or you whichever goes first).
I sourced an entire EAS system, including the computer, valve block, springs, compressor, and tank off of EvilBay for $105. I bought another valve block refirb kit for an additional $10 and a compressor piston kit for $40. So, I have an entire system with swapable spares for just north of $150. I like this solution much better than the coil route since my Rover is mostly a street machine.
Bottom line is that there is a way to keep and maintain the air suspension system if want to keep it without breaking the bank. I personally think that the suspension system as designed, and when working correctly, is a key feature of the truck. The hang up for most folks is the cost if you depend on a dealer doing all your service and repairs. (substitute 914 and its features in the sentence for the same conclusion
