I agree on the Getty stuff. Great customer service. I bought GT rockers from them. The left side had some waves in it and my painter was not happy, although it was typical of fiberglass parts from most places. I decided to call Getty. When I called about it, they said it was time to do some repair work on the mold. In a week or so, they delivered free of charge a flawless new rocker. Now THATS customer service!
In my opinion, I think people get a little carried away with the openings for coolers.. If the cooler is mounted directly against the sheet metal, you might have to cut a full size hole to prevent air blockage. If it's set back a little, you may not need such a big hole. Remember, the coolers actual air opening is significantly smaller than the actual size of the cooler. You need no more than what can flow through the cooler. It is tempting to think bigger is better.
With that said, I enlarged the holes in the front with a Greenline tool and avoided the full cut out in the front. The area of the openings far exceeds the openings of the cooler. The cooler sits quite a ways back from the holes.
Click to view attachmentClick to view attachmentClick to view attachment
