QUOTE(dr914@autoatlanta.com @ Jan 11 2007, 09:15 PM)
I would agree. Simply weld the holes grind flat and then have rechromed. One can tell the guard bumpers from the non guard bumpers as the guard bumpers had two extra reinforcements behind the guards for absorbent rubber blocks to fit. Non bumper guard bumpers are clean except for the mounting plates on each end.
I'd agree with closing the holes with welding (make sure they use good metal). Just as importantly, make certain they grind/sand them down to flush. if you don't use good metal & grind it down properly, they will be more than noticeable.
For my money, I'd sooner look for a proper bumper, even if it must be redone. I think that 5 years down the road you'd be better off.
But....MHO
