Since I don't have anything to do tonight. I thought might jump in on this and try to complicate the shit out of it....
SO::::::::::::I
Ya don't need a mill to remove seats. Takes way too long.
I just throw a bead on em from a tig and they fall out.
NEXT::::::::::
I HIGHLY suggest you use a machinist with TYPE IV head experience.
These ain't type 1 heads. Len or Adrian are known excellent TYPE IV head machinists.
There are others. I just don't know them.
You should also get NEW exhaust studs.
(Jake and/or Len have the best chromo ones available)
Seat and guide installation and shoddy aluminum welding is where most machinists screw these heads up. (among other things)
If it is not done dead perfect. It will cost you tearing the engine apart again. After you suck said valve and seat.
And yea... you will need bigger valves to make it scoot.
And NO... you wont polish the intake runners in the head. As that promotes wet flow issues. Exhaust.. OK.
Yes you can assemble the heads. The rocker arm setup anyway. As the heads will come back form the machinist with valves installed.
Now ya have to figure out:
What cam? What springs for the cam? What lifters? 911 adjusters on 1.7 rockers with the rockers decked to accept 911 adjusters? or stock rockers and adjusters? Lash caps if using stock adjusters on dual springs? or single springs??
What pistons? What ring pack for the pistons? What rods? What rod bearings........?? Jakes excellent Double thrust cam bearings or stock cam bearings?. What weight and dia. piston pins?, which oil pump?, chromo or aluminum pushrods? Stock rod or rabbit rod? Or other rod?
Tuna can with extended sump tube or not? What cam? What lifters?
Are you going to have the heads professional flowed so you can determine flow numbers which will help dictate the appropriate cam?
What compression ratio? And why? What deck height?
I could go on forever.
I B sniffing that you might want to do a BOAT LOAD more homework on this build.
A 2.2 engine is going to need some thorough design and implementation to be efficient and have longevity.
Have you thought about what exhaust you are going to run? And at what cost?
How about induction?
Aftermarket EFI, Carbs, or try to make the stock FI work... so on...
What about spark? Mallory? Pertronix in a stock dizzy? etc.
There is a shit load of data needed to make sure you aren't gunna build a engine that will run hot, and be less than it it could of been, if built and designed correctly.
In truth... I really don't know shit. I do know what I need, to build one of these engines to MY spec.
It took me a year of homework living and breathing all of the type IV forums and spending untold hours researching... Just to understand what it takes to safely create maximum output, longevity, Great BSFCs, and do it for less than a pro would charge for it. I bet you I have spent THOUSANDS of dollars in time at machine shops talking, machining, giving, learning, simply to learn what I do know about these engines.
It's been a fun and rewarding journey.
Note: I have a pretty good backround in engines and race cars.
After what I learned about these engines.. I had to throw half of what I know in the trash.
Run over to
STF forumsUse the search function... And read for a week straight.
Then post up what you want to accomplish. These guys are TYPE IV nutz like us.
And there are some fellas there that will take you (and me) to school.
You WILL get what you need. Cept I think you ain't gunna like what it really takes to do it right.
Aw hell.... you probably know all this stuff already....
But just in case... I thought I would throw this stuff out...
Cheers,
Clayton
