Full Version: CV joint Bolts
r_towle
What is the racing trick to keep these sucker tight???
Is it just part of weekly maintenance???
Or, is there a fabbed kit out there to put in longer bolts and a nylon nut on the back?
Or, how about drilling out the heads and wiring them in somehow?????
Rich
brant
Use the factory style correct lock washers....
Use New ones.
b
redshift
Yes yes. Make sure the new ones you use are super-clean before you install them, make sure you use the proper torque.
I haven't had a lose one in just over 13,000 miles.
-wood knocking smiley-
M
r_towle
Are these the wavy washers or conventional lock washers??
I have both in the box of bolts from my 914's, just want to use the right ones.....
Rich
JWest
QUOTE(r_towle @ Nov 20 2003, 07:18 AM)
Rich
Neither - it is a Schnorr washer and it is serated on both sides and dished.
edgetoo
I believe that the washers are narrowand seriated. We also use the 2 hole plate. Once torqued. they seem to stay tight, but we check them every other race or so. (While road racing does not stress them that much, missed down shifts and bumps while accellerating can be sharp loads.)
brant
But the trick in my opinion.. is to use New or nearly new washers...
I think you can order a set of new washers for about 5 bucks... a pretty economical safety investment.
brant
r_towle
Thanx, found em,,,, look worn out I think a new set is in order.
Rich
fuch toy
Saw a set someplace....had holes drilled it the heads for safety wires.
But with proper washers "I" never had a set work loose....
JWest
Part # 999 523 102 01
Qarl
Lookie lookie... 3 bags of schnorr washers came today!
ArtechnikA
QUOTE(r_towle @ Nov 20 2003, 06:40 AM)
... Or, how about drilling out the heads and wiring them in somehow?????
yes, new washers, every time. torque the fasterners to spec, 33 lbs/ft IIRC.
i drill them for safety wire, no 'somehow' to it, really. i wire them in pairs.
standard 0,032" safety wire twisted with safety wire pliers. hit the side of the head with a small grindstone in a Dremel, then use a 1/16" cobalt bit in a drill press; use plenty of cutting oil, NBD.
i like to re-torque the inboard ends after a week of road use and then wire them, the outboard ends get it before installation.
some use a half-height Nylock nut on "too long" bolts; i've never done that but i'm sure it'd work.
Brad Roberts
Karl..
why in the world would you order that damn many ?? You need 16 total for the CV's and 12 total for the rear control arms.....LOL
B
redshift
That killed me too...
I don't think I have ever owned that many, total, ever.
M
Qarl
I like to make necklaces out of them.
Actually they were cheap. Anybody want some schnorr washers?
redshift
You need to get to sleep, so you can work tomorrow, so you can afford to keep them.
M
Qarl
finger.gif ha ha
Brad Roberts
B
Qarl
Yeah yeah... make your fun.
If you can find a cure for my insomnia and anxiety that would be great.
Well, just to let you know... I stopped by the PC after I went to take a wizz. I looked down at the toilet and thought of you guys!
