pete-stevers
Jan 20 2007, 11:36 AM
i want to put a head temp guage in the console....
jsut wondering where does one mount the temp sending unit??
and which head runs the hottest....
ptravnic
Jan 20 2007, 11:40 AM
#3 cylinder runs the hottest (from what I've read).
BigDBass
Jan 20 2007, 12:46 PM
At some point, I'd like to swap the brake warning light in my combo gauge out for oil temp, then CHT into the center console.
pete-stevers
Jan 20 2007, 12:53 PM
my original plan was to use a triple 904 guage...
but i have revised to just using the 911 oil gauge as is
and run my gas , head and alt on the console....
i need spacers for the smaller gauges in the center console....
Grelber
Jan 20 2007, 12:54 PM
I'm in the middle of putting extra gauges into my center console (CHT and oil pressure). Just cut a piece of HDF wood the same size as the original, a hole saw for holes to put the gayges thru, and about $2.00 worth of black leather-look vinyl from the fabric store. I've seen 5 staggered in it, and they fit fine. Doing it all for under $5.00 (less gauges).
BenNC
Jan 20 2007, 05:53 PM
Why choose? I picked up a switch at Radio Shack and put a sensor on each head, so I can just switch back and forth.
When I put everything back together, I'll fix it so that the switch is pointing at the head that is being monitored. Oops
Rand
Jan 20 2007, 07:54 PM
Yes, sender under #3 sparkplug. I think it's super cool to have a switched setup with multiple senders, but your important temp figure is the hottest one. So use #3 until you go multiple.
I just replaced the clock in my center console. My VDO gauge was a little smaller in diameter than the stock gauges/clock, so I used a piece of ABS plastic pipe to make a sleeve. The dimensions were perfect.
pete-stevers
Jan 20 2007, 07:57 PM
perfect....that should have been a question as well!!!
the adapter kits are no longer available...
pete-stevers
Jan 20 2007, 07:58 PM
what is the hottest cylinder head on a six
pete-stevers
Jan 21 2007, 11:20 PM
i am still wondering which cylinder on a six runs hottest
and where does one mount the sensor, is it just a standard vdo sensor?
John
Jan 21 2007, 11:25 PM
Pete, On those CHT gauges, the sensor simply mounts under a spark plug.
I don't know which cylinder is hottest on a 911 engine. I'm still waiting for someone to answer that one.
bperry
Jan 22 2007, 02:23 AM
QUOTE(pete-stevers @ Jan 20 2007, 07:57 PM)
By adapter kit are you refering to these VDO adapter rings?
I bought these years ago. They slip over the gauge and
adapt the smaller gauges to the older larger gauge holes.
They work great in the console.
--- bill
Joe Bob
Jan 22 2007, 03:49 AM
The cylinder in the middle runs the hottest......the rings are called "reducers" and are still available from VDO.
jr91472
Jan 22 2007, 08:01 AM
Can someone please direct me where to find the sending unit for CHT guage? I am not sure why I can't find em
bperry
Jan 22 2007, 05:54 PM
QUOTE(jr91472 @ Jan 22 2007, 08:01 AM)
Look here:
CB PerformanceIts only $10.
You may want to call, there used to be two versions of the sender.
I think they were the same but with different diameter holes.
--- bill
