swood
Jan 20 2007, 10:38 PM
Can anyone give me a quick measurement to locate the lower mount?I don't have the engine lid in or stock springs to help me figure out how high up the trunk should raise. Ready to drill...
Tanks.
pete-stevers
Jan 21 2007, 12:29 AM
don't you dare drill untill you are damn sure....
did you not get instructions???
i would measure but i am at home and warm.....shop....cold
swood
Jan 21 2007, 10:27 AM
boxstr
Jan 21 2007, 03:58 PM
Steve put the shock on the upper mount, remove the lock ring first. Then lower the lower end of the shock to the side of the trunk, position the lower bracket and mark with a Sharpie. This will give you the location to drill at.
If you need me to I can fax or send an instruction sheet.
Craig C. Laughlin CAMP 914
swood
Jan 22 2007, 12:14 AM
I have the upper mounts on, but don't really know what the full range of opening the hood should be in order to place the bottom mount. That's kind of where I'm stuck. I have the instructions you included.
This reminds me I need to send you $.
boxstr
Jan 22 2007, 12:26 AM
Steve,I can take a measurement on a car in the morning call me at 503-799-5794.
Craig
Lou W
Jan 22 2007, 01:18 AM
I did not have my trunk lid on when I mounted mine, I put the hinge in the maximumn open position, attached the shox with the trunk base mount attached and located it accordingly. It worked fine.
Lou W
Jan 22 2007, 01:22 AM
Here a couple pictures completed;
