Full Version: FI Guru's
r_towle
Hi,
What does a generic Mass Air Flow sensor measure?
Does it measure volume? velocity? pressure?
And, is there a generic one that could be read via a serial cable to a laptop?
A kit is cool, or a homemade version is also fine.
Rich
banger
Actually it does what the name implies... It measures the MASS of the air flowing. They are pretty simple devices. If you buy a Ford MAF, you connect it to 12V and Gnd, and it will output an analog voltage proportional to the amount of air flowing through it. It is fairly linear, and there are charts on the web that will tell you how much air corresponds to a given voltage output. If you have a multimeter, you can measure the voltage, then look it up on the chart and see the amount of air. Ideally you would want to find one that is from a car with similar horsepower to the one that you will be putting it on. Otherwise you will decrease your resolution if you get one to big, or run out of resolution if you get one too small. The principals of them are pretty simple. The old VW ones basically had a flap that would move in response to the airflow. Most modern sensors are the heated wire type. They use 12V to heat a wire to a specific temperature, as airflow increases, the wire cools, and they have to add more power to keep the wire at that temp. They measure how much additional power is needed, and this gives you the reading for airflow.
r_towle
My idea is to build a simple flow bench to MATCH flow some heads.
All I want is to ensure they are the same, so I dont need the full benefits of a flow bench.
I think that an MAF will work for this purpose, and even just a multi meter.
Is there a way to check an MAF at the junk yard?
Ford or whatever is fine.
Right now the ports do not match, im sure.
Rich
Mid_Engine_914
The Wikipedia article below says that the Vane type sensor measures air volume and the Hot Wire sensor measures air density.
http://en.wikipedia.org/wiki/MAF_sensor
http://en.wikipedia.org/wiki/MAP_sensor
http://en.wikipedia.org/wiki/Fuel_injection
Automotive mass airflow sensors
A mass airflow sensor is used to determine the mass of air entering the engine. The air mass information is necessary to calculate and deliver the correct fuel mass to the engine. Air is a gas, and its density changes as it expands and contracts with temperature and pressure. In automotive applications, air density varies with the vehicle's operating environment, and is an ideal application for a mass sensor. (See stoichiometric, ideal gas law, and density.)
There are two common types of mass airflow sensors in usage on gasoline engines. They are the vane meter and the hot wire. Neither design employs technology that measures air mass directly. However, with an additional sensor or two, the engine's air mass flow rate can be accurately determined.
Both approaches are used almost exclusively on gasoline burning, EFI (electronic fuel injection) engines. Both sensor designs output a 0 - 5.0 volt signal that is proportional to the air mass flow rate, and both sensors have an IAT sensor (intake air temperature) incorporated into their housings.
When a MAF is used in conjunction with an exhaust gas oxygen sensor, the engine's air/fuel ratio can be controlled very accurately. The MAF sensor provides the open-loop predicted air flow information (the measured air flow) to the engine's ECU, and the EGO sensor provides closed-loop feedback in order to make minor corrections to the predicted air mass.
(Also see stoichiometric and MAP sensor.)
Vane meter sensor
A vane, or paddle, projects into the engine’s intake air stream on a spring-loaded arm. The vane moves in proportion to the airflow, and a voltage is generated in proportion to the distance the vane moves. The vane measures air volume, not mass, however by measuring the air temperature and pressure to determine air density, a true mass airflow calculation can be achieved. (See ideal gas law.)
The vane meter approach has some drawbacks:
it restricts airflow which limits engine output
its moving electrical contacts can wear
finding a suitable mounting location within a confined engine compartment is problematic
the vane has to be oriented with respect to gravity
Hot wire sensor (MAF)
A hot wire mass airflow sensor determines the mass of air flowing into the engine’s air intake system. This is achieved by heating a wire with an electric current that is suspended in the engine’s air stream, not unlike a toaster wire. The wire's electrical resistance increases with the wire’s temperature, which limits electrical current flowing through the circuit. When air flows past the wire, the wire cools decreasing its resistance, which in turn allows more current to flow through the circuit. As more current flows, the wire’s temperature increases until the resistance reaches equilibrium again. The amount of current required to maintain the wire’s electrical resistance is directly proportional to the mass of air flowing past the wire.
If air density increases due to a pressure or temperature change, but the air volume remains constant, the denser air will remove more heat from the wire indicating a higher mass airflow. Unlike the vane meter's paddle sensing element, the hot wire responds directly to air density. This sensor's capabilities are well suited to support the gasoline combustion process which fundamentally responds to air mass, not air volume. (See stoichiometric.)
Some of the benefits of a hot-wire MAF compared to the older style vane meter are:
responds very quickly to changes in air flow
low airflow restriction
smaller overall package
less sensitive to mounting location and orientation
no moving parts improve its durability
less expensive
separate temperature and pressure sensors are not required (to determine air mass)
There are some drawbacks:
dirt and oil can contaminate the hot-wire deteriorating its accuracy
installation requires a laminar flow across the hot-wire
banger
You can probably pick up a MAF from a ford escort or something similar. You dont want one too big, since you will be measuring the flow through just one head. If you look at some of the megasquirt fuel injection pages, they will show the pinouts for the ford sensors. Ford MAF info The only thing you will need to be careful of, is temperature and barometric pressure. Since you are measuring the mass of the air through the heads, it will vary slightly with temperature and pressure. If you are matching 2 heads to each other, then this should be an issue since you will probably be comparing them fairly close to each other instead of days apart. You could also correct for temp and pressure, if you like to do a lot of math.
banger
Here is another chart for the mustang MAF. This one is a bit more detailed. Mustang MAF chart For your purposes though, if you are just matching, the specs do not matter as much, since you are looking to get the same voltage reading for both heads. When looking for a MAF, try to find one that is reasonably clean. Since it is basically a heated wire, dirt and oil will affect its reading. Once again, even this is not that important, since you are just matching readings. You can usually pick up a ford MAF pretty cheap. I just bought one for my megasquirt conversion for $10 on ebay.
