QUOTE(autohausdolby @ Jan 23 2007, 05:06 AM)
What engine would street and race /6s have had in 1970? Am I right in thinking it would have been a 2.0 litre "T" engine?
street, yes.
race, no -- the 914.6GT was basically a 906 engine. the 1970 911T was a 2,2 liter engine.
What's the difference between a street engine and an 'average' period race engine apart from the twin plug heads/ignition system?
in 1970 - the 906 engine was based on the aluminum crankcase. after that, it's your standard "cam, compression, and carburetion" differences - with the appropriate 'details'...
Are there any specific weaknesses on 2.0 litre engines?
not once you realize that there is a big difference in preparation for a race engine. shot-peened and polished forged rods, forged crank, porting, exhaust, some oil system tweaks...
What is the bore and stroke?
80x66mm
What is the difference between a 911 and 914/6 2.0 litre motor?
a 914.6 street engine was a continuation of the 1969 911T engine (110DIN HP) there were also 2,0-liter 911E and 911S street engines - 'S' was rated at 180 DIN HP. cams, compression, carburation - E and S had MFI that was good for another 10-15HP.
Are there 'other' 2.0 litres that are different (so I end up with the right one!)?
911T - basically the same with detail differences (oil cooler, carburation, flywheel. 911E and S, as covered above.
Are the 2.0s worth more or less than the later, larger displacement motors?
depends. you won't win a national-level concours d'elegance with the wrong engine. 2,0's cost at least as much to rebuild as the bigger engines, and the newest is 35 years old.
If you really want to research this stuff, in addition to the other suggested references, read Paul Frère's "Porsche 911 Story" which covers all the detail differences and evolutions across the development of the 911 engine.
What identifying marks/codes do the engines have?
The Type Number (911/xx) tells you what the engine started as - assuming nothing changed when it was rebuilt somewhere in its 40-year life (never a good bet). There is also a serial number that can sometimes be used to track back the production data, but only a few people keep all the production serial number data close at hand, and lots of people have a reference of the Type Number. Type Number will be to the right of the fan housing on the horizontal surface of the case.
