QUOTE(herman maire @ Jan 25 2007, 08:23 AM)
[quote Does anybody know if KONI still makes there external adjustment shock or do they only have the ones where you have to compress the piston and turn the valve ?
Yep, Koni external adjustment. Bought at Shox.com. Took them to Ground Control and set them up from there. Note that the OD of the Koni's is a little goofy and it took a larger sleeve with a "makeup" spacer. It's hard to see, but if you look closely at the picture, you will see a goldish colored ring right below the red threaded section. This allowed the larger threaded pearch to slide easily over the shock and rest on the makeup spacer. When the shock is upright, the makeup spacer is actually inside the threaded sleeve and you can't see it. The smaller threaded sleeves (that almost fit) requires a little grinding of the shock paint to get them to slide down. I avoided that for warranty concerns.
