I did do a thread search first and of course found quite a bit about vacuum lines, but I didn't see anything specific to carb applications. Most of it was related to FI and appeared a fair bit more complicated.
I've got a 1974 2.0 with dual Webber 40's and non-vacuum advance distributor (mechanical). The way the car is plumbed is the ports on both heads are T'd into the PCV at the oil fill, and this is T'd to a hose running back to a port on top of one of the air filters.
Is this how most other carb set-ups are plumbed? What are the ports on the heads for? Just vents? And it seems some heads have them & some don't (late vs. early maybe). And should they be tied to the PCV?
Also, I would think from past V-8 experience that the PCV would be tied into an intake manifold instead of on top of an air cleaner (i.e. more vacuum). Of course there is no port on the manifolds, so this may be the best you can do.
Anyway, some insight would be helpful.
Thanks,
dt
