QUOTE(shaggy @ Jan 28 2007, 09:16 PM)
how do i change the shift bushings in/on the shift rod from my 72
i have the back half of the rod removed and do not see any of the bushings.
On the end of the trans by the tail shift rod is a bracket that bolts on, your shift rod passes thru it right at the rear of the car, one goes there.
how do i remove the front half?
I don't think I did to replace it, I think I just worked it around that 90 degree
pivot off and on.
and how do i change the balls and the ball socket on the bottom of the shifter?
-jim
The nylon socket just pops off of the ball at the end of the shifter. I removed the ball on the shifter to put on a quick shift kit, I used mapp gas to heat it up and
it tapped off. You will epoxy the new one on.
