QUOTE(Cap'n Krusty @ Jan 29 2007, 09:17 PM)
Nice. Detailed. Complete. TOO BAD IT'S THE HARD WAY! You can read the same BS on the Bird Board. Go here to see how the real wrenches do it:
http://www.914club.com/bbs2/index.php?showtopic=28758Once you've done it my way, you'll laugh at the very thought of doing it the other way.
The Cap'n
Actually, after reading your method from the "original" 914club site -- as well as what was posted on Pelican -- and what the shop manuals instruct, I don't consider your method any simpler by a significant magnitude and you
still fail to instruct the person how to get to the darn valves in the first place!
If someone doesn't want to remove the heater parts, fine, it's not necessary. But for me it made life WAY easier in adjusting the forward valves. Maybe laying on my back on a creeper isn't the way to do this?
I think positioning the dizzy at #1 firing position and then using the marked flywheel as a guide is more accurate than watching the rockers move as you spin the tire. This valve adjusting method is very simple, accurate, requires no guess-work, and would take no more time (and probably less) than your "spin the tire on the Porsche" method.
As for the insulting comment about "real wrenches", this [valve adjusting] method was told to me by two certified VW dealership mechanics of over 20 years experience each (one of which had his own independent shop as well), and is used by other VW nuts with far more experience than you. I've used it on my dub for years as well. Get off your high horse, you're not as great as you think.
