jimkelly
Jan 29 2007, 08:56 AM
is it more a problem of not being good to downshift into 1st from 2nd or is it more of a dead stop start in 1st - could destroy tranny and why ??
thanks
jim
Dr. Roger
Jan 29 2007, 09:24 AM
1. It's the weakest gear and many have blown it.
2. 901's are geared for a 4/6 cyl. engine and is very low. Too low for a V8. Have you noticed that it is "etchy" when applying the throttle. So much torque comes on so quickly and causes a surge/jerk forwards and back and forward and back. It's controllable but ...
jimkelly
Jan 29 2007, 10:01 AM
Yes - I have only driven my car about 100 feet so far in 1st gear only - as I have no shift linkage yet : )
It seems to me that 1st might be good for only up to - what - 10 mph ??
For next short joy ride - I plan to manually put it in 2nd gear : ))
Jim
sean_v8_914
Jan 29 2007, 10:03 AM
first gear hangs off teh end of the cluster supported by teh shaft on one side only. torque of a v8 is a bit much for it there. you can use 1st to move around teh yard or to put it on teh trailer...and what teh good DR said
Aaron Cox
Jan 29 2007, 10:46 AM
its cantaleverd off the intermediate plate with only a bearing on one side.....
alpha434
Jan 29 2007, 11:52 AM
Dude. First gear is fine.
If you need to do any rock crawling, it'll be there!
jimkelly
Jan 29 2007, 12:00 PM
me and ROOT rebuilt a side shift for my v8 conversion that we finally got moving under its own power - sort of - yesterday. i know i could have blocked off first gear but figured - what the hell - fix it up too - must have had rock climbing in the back of my mind : ))
so anyway ...
ratio not much use with v8
canterlevered = weakness
thanks guys
jim
Mid_Engine_914
Jan 29 2007, 12:06 PM
It's not a good idea to use the 901 tranny with a motor with that much hp.
http://www.914world.com/bbs2/index.php?sho...=66161&st=0
jimkelly
Jan 29 2007, 12:18 PM
thanks for link - i will keep all posted on my experiences - jim
no hard clutch dropped launches are planned - my v8 is mostly for a bit of added hustle and reliability.
easy - gradual - peddle depressions are my intention : )
messix
Jan 29 2007, 02:19 PM
can you say BOOM!
actually gavel gravel gravel [the sound of nuts and bolt in a coffee can when stired]
jimkelly
Jan 29 2007, 02:28 PM
from downshifting in to 1st from 2nd ??
from dropping clutch at 3000 rpm ??
from simply mashing the gas in 2nd ??
jim
QUOTE(messix @ Jan 29 2007, 12:19 PM)
can you say BOOM!
messix
Jan 29 2007, 02:50 PM
anything involving first gear above idle.
then anything that would break the tires loose in the wet.
no clutch drops [300-400 ft lbs torque + small gears,syncros and thin shafts= boom!]
fiid
Jan 29 2007, 03:40 PM
I guess the issue is that if you block it off you probably won't break it, but if you do break it off - you're not going to be able to use the broken shaft anymore... you'll have to find another one. It's not going to break in the right place such that you can keep using it - so you might as well set it up so you can't break it and save yourself the issue later.
It's not necessarily going to be something intentional... you might have wet feet and your foot slip off the clutch or something.
While you're in there - you'll probably want a taller 5th. I only have a subie motor and I want a taller 5th...
jimkelly
Jan 29 2007, 05:14 PM
taller 5th - i will cross that bridge when I get to it.
can't imagine needing it for as sub - max rpm is higher than type4 - isn't it ??
don't really want to spend any more bucks if I can help it.
i am cool with running 65 mph at 3500 - i think - except maybe for mpg's : )
i'll let you know though ??
jim
messix
Jan 29 2007, 07:22 PM
ahhh a V8 at 3k on the freeway for an hour is against the Geneva convention for cruel and unusual punishment.
jimkelly
Jan 29 2007, 07:32 PM
now that is funny - i will confirm or refute this to be true as soon as i can - within 30 days I hope - thks - jim
QUOTE(messix @ Jan 29 2007, 05:22 PM)
messix
Jan 29 2007, 07:52 PM
just "ask the man who owns one"!
[old packard sales line]
sww914
Jan 29 2007, 08:18 PM
If you floor it in first, you can twist the end of the shaft right off. I've seen one. That's the short term- the long term is the cantilever problem, mauling it in first all the time will blow out the bearing or worse. If you baby it in first you'll be fine, until something else goes.
messix
Jan 29 2007, 08:21 PM
i would think first would be good to have to idle it up on a trailer if thats your thing.
pffft
Jan 29 2007, 08:57 PM
QUOTE(messix @ Jan 29 2007, 06:21 PM)
Yeah, that's my thinking. I have a long steep dirt 1st gear
driveway and some very tight turns to get into the
garage. I know my 2.4cis motor was fairly happy starting
in 2nd, and I figure my very mellow 327 makes much more
torque at idle, but for getting from the road to my garage the
six was not AT ALL happy in 2nd.
Hopefully I'll find out soon.
patrick
burton73
Jan 29 2007, 10:04 PM
I had 914 with a 283 Chevy and a mild cam. With 901 trans. Nothing to radical. The car never needed 1ST gear. When I got on it too much at the red light it popped the CV joint. It needed to be driven mellow from the light because I was scared I would break something before it sold. I only got the car to resell it. I made a bunch of money on it and learned a lot from it. This was 26 years ago. It was a running car at one time and the guy I got it from pulled all the good stuff off and gave me the parts to refinish it. I was driving a 1973 914 4 cylinder 2 .L Turbo built by Galen Bieker that was fast. Now the Chevy was quick but the turbo was fast.
Bob
Andyrew
Jan 29 2007, 11:34 PM
Joyrides are much better done in 3rd gear. (trust me.. I've done single gear drives..)
Plenty of tq.
1st isnt needed.. often.. Cant get it in second? try third.. No go? Go for 1st Does it work? No worries, dont put more power to it than the stock 4 cylander gives it, it'll be fine.
Andrew
jimkelly
Jan 30 2007, 07:13 AM
3rd gear - got it
*note to self - add brake fuild and bleed brakes before 3rd gear joyride : )
so v8 has enough torque to pull easily from a dead stop in 2nd gear thus making 1st gear essentially useless.
type4 could not get going decently from a dead stop without 1st gear due to lack of power/torque.
jim
iamchappy
Jan 30 2007, 08:16 AM
I use 1st gear more or less as a roller to get going, sometimes I start in 2nd, as long as you dont beat on it it's fine. The 901 is not the transmission for drag racing so dont use it for that unless you dont mind breaking it, if driven carefully it should hold up.
I am using the 901 with my 3.1 turbo engine so I plan on rolling on the throttle instead of jumping on it to prolong it's life. I am also using a trans cooler to keep the temps down.
jimkelly
Jan 30 2007, 08:40 AM
I'll be keeping my 205x15x50 - not as tall as stock - so this too will raise rpm's at highway speeds : (
But having skinnish tires should reduce stress on transaxle, axles, cvs, suspension parts - is my hope.
note to self - no drag racing : )
note to self - get 930 tranny - kidding : )
