spunone
Jan 29 2007, 05:10 PM
Who sells the oil presure relocate Kit?? Thanks
Aaron Cox
Jan 29 2007, 05:19 PM
aircooled.net is where i got my braided stainless one from...
jake has em too im sure...
its 1/8 npt... a basic hydraulic hose has been used many a time...
spunone
Jan 29 2007, 05:20 PM
Thanks Aaron
spunone
Jan 29 2007, 05:33 PM
Got a Part number off hand I'm lazy
Aaron Cox
Jan 29 2007, 05:35 PM
pffft
Jan 29 2007, 05:40 PM
If you order on line, they will ask which threads, my 2.0 was 10X1 mm
patrick
spunone
Jan 29 2007, 05:50 PM
Ok A C which sending unit?? why the 2 sizes just wonderin out LOUD
Jake Raby
Jan 29 2007, 06:00 PM
I'll sell ya one..
OR go to a local paint ball supplier, the main pressure hose for a paint ball gun is the exact same length and etc as you need for the TIV!
Cap'n Krusty
Jan 29 2007, 06:09 PM
There's ONLY ONE size, 10x1.0mm. Don't trust anyone who tells you differently. 1/8" NPT works just fine. Grease gun hose from your FLAPS. Couldn't be simpler. BTW, you'll need a clamp, the kind used for holding hoses in place, and a ground wire for the sender unit. The Cap'n
Grelber
Jan 29 2007, 09:14 PM
I've got to do this on mine. Can someone give me a picture of what it should look like (with the hose, etc.)
Thanks.
Krieger
Jan 29 2007, 10:20 PM
You don't need no stinkin' relocation kit. If thats your motor in your avatar and its still out of the car. Take the tin off and enlarge the hole in the engine tin. My sender screwed right into the case. You don't see it and you have a lot less chance for leaks down the road.
Aaron Cox
Jan 29 2007, 11:07 PM
QUOTE(Krieger914 @ Jan 29 2007, 08:20 PM)
you didnt have a mallory dizzy which is quite the porker... its very big... and IT WONT FIT
you DO need the hose
2-OH!
Jan 30 2007, 02:04 PM
North Hollywood Speedometer sells the complete kit...Hose, Clamp, Sender...Better hurry, he only had about 40 last time I was there...
2-OH!
dr914@autoatlanta.com
Jan 30 2007, 02:40 PM
watch the fit of these things. Someone is using the wrong thread pitch and they strip into the oil pressure hole. The kits look great but MUST use an adaptor!!!!!
SGB
Jan 30 2007, 03:05 PM
That bit of knowledge could avert a big disaster. Thanks George!
