QUOTE(herman maire @ Jan 31 2007, 08:39 AM)
I have been looking at another members pics and this is one of them I kept. Is this the best place to cut metal?
That be mine
I have two Dzus on the front that attached to the "bumper", 2 by the headlight buckets, and 4 (two down each side) right in front of the door. I have actually seen that front end attached with 6 total on another car (!) but wanted a few extra to be safe.
I put a LOT of fasteners along the top of the rear fenders because they were so flimsy they would "buckle upward" with just a couple, so I put a few every 6-8" to force the fender to fit the body nicely. For each fender, you could run 2 behind the door, 3 along the top edge, and one down by the rear valence if you don't have as much "uneven-ness" like I did.
You can hack those fenders completely away if you have full fenders like the Sheridan kit I do - most of the race cars with removeable fenders are like this (where I got the idea for my cutting frankly - Chuck McKinney had one of the first Sheridan kits on his 914-6 and I matched his cuts more or less - his car was in Excellence in the mid or latter 90s IIRC). As for the front where I cut out for the radiator I would NOT recommend that - unless (what you don't see in that pic covered by the trunk floor board) you add cross bracing in the front. I don't have a pic of my bracing at the time, but that section is structural between the front susp mounts.
Here are some better shots that may help you - you can see the original 4 mount points at the front (now I have just the 2 by the signals - the radiator blocks the others but I added a splitter at the bottom that holds the nose very well now.
Click to view attachmentA rear shot - I have around 10 per side to fit those fenders, but again you could do two by the doors, 3 along the top and one down by the valence if you don't mind the fenders not quite fitting flush.
Click to view attachmentAnother showing the holes at the rear. The car has changed quite a bit but the fenders still mount the same
