QUOTE(nine14cats @ Feb 2 2007, 08:00 PM)
QUOTE(Dan (Almaden Valley) @ Feb 2 2007, 05:07 PM)
Bill, get them and let Doris heat cycle them for you and let her wear down the first 2/32. At her learning pace she will never be able to tell the difference. Or take them to an AX and run them for 1/2 the day and then put them away for awhile...
Free is always good....did you run across any 205s
Should I then buy a matching set of unshaved rear tires? The problem here is that I'm a lazy bastard and I don't want to switch tires for Doris or I unless it's for timed runs. But I'm also thinking of NOT running the time trial series and only letting Doris run them to save wear and tear on the car. Since I have Amanda's wedding to go to I've decided to skip the Infineon event and I'm missing TT#2 due to Doris' graduation for her MBA. So I'm going to have a hard time pointing out enough to win a class.
Doris can compete in Ladies and probably win with only 3 events. I can't. So I can use the money on other open track events such as my NASA licensing.
I didn't find a stash of lost 205's yet.
Bill P.
I agree with Dan as one would think that the brand new Victoracers (unshaved) would be safe (most important) as well as effective for Doris.
But before you let her out why don't you run them at a track day, at a known venue just to see how your times vary from previous runs. Of course it won't be exact science given the difference in (rear) tire sizes, but it will be an interesting base line.
And if the unshaved tires are dramatically slower or don't handle, as you'd like at speed, then swap them out.
