QUOTE(will @ Feb 3 2007, 08:31 PM)
falken azenis rt615 recommends a max of 50 psi. I currently have it at 40 psi. would you go higher?
for AX, the lower, the better.
lower tire pressure means more stickage. until you start rolling over the sidewalls ...
start with your 40, mark the sidewalls, find a empty parking lot, do a few nice turns and see if the sidewalls are rolling over.
if not, drop pressure until you can clearly see them flexing, then up by 2 pounds or so.
that should get you very close to the optimum. just remember, when running, pressure will increase with heat, so once you know your prefered temperature, make sure you check them (and bleed if needed) after each AX run ...
for the street, i'd set them a few pounds over your AX pressure, ~5lbs plus or so ...
i'm running my street tires on 32lbs ...
Andy
