Aaron Cox
Feb 3 2007, 11:17 PM
well today was a long one......
clayton (twystd1) came over to assist in finding either an exhaust leak or *gasp* a headleak that i had begun to hear.....
and then bill (grimstead) came over to play with his webers ....
fast forward several hours later.
My motor is out. In the back of my truck.
Bills car is dialed in pretty close. needs a valve adjustment first.
my motor is going to get its heads pulled... and *MIGHT* see a a CR and CC increase....
so yes... pics later. im betting headgasket died.....
while your in there.... lets make it faster LOL
so.. where is the hookup on 96mm KB pistons? ill have to drop a dime and call jake up.
good day had by all. In N out... bro's...car's... and making noise in the neighborhood...
AA
Joe Bob
Feb 3 2007, 11:19 PM
Will Clayton answer his phone?
Aaron Cox
Feb 3 2007, 11:29 PM
QUOTE(mikez @ Feb 3 2007, 09:19 PM)
will the price of rice in china affect my motor work?
Joe Bob
Feb 3 2007, 11:39 PM
I need some advice on my megasquirt....it runs like crap when cold.....pop,pop,pop......
So.Cal.914
Feb 3 2007, 11:41 PM
Depends on who you get your P & C's from.
swood
Feb 3 2007, 11:43 PM
Yeah but who fed you? All worky on empty belly no bueno.
I got my 96mm KB's at EuroMotorworks on Hawthorne Blvd.
Aaron Cox
Feb 4 2007, 12:43 AM
my folks bought lunch (solid!)
i have cylinders (oem 94's...) whats the skinny on KB 96 pistons?
banger
Feb 4 2007, 12:44 AM
Popping in the intake? too lean
QUOTE(mikez @ Feb 3 2007, 09:39 PM)
McMark
Feb 4 2007, 12:45 AM
Don't forget, Bill's engine needs zero lash when cold. NOT 0.008"!
Aaron Cox
Feb 4 2007, 12:46 AM
QUOTE(McMark @ Feb 3 2007, 10:45 PM)
duh! chromo pushrods like mine...
Joe Bob
Feb 4 2007, 01:30 AM
QUOTE(banger @ Feb 3 2007, 10:44 PM)
Duh.....
DNHunt
Feb 4 2007, 08:40 AM
Mikey did you add in Waemup enrichment and does it vary with engine temp? Where is the sensor located?
Dave
Aaron Cox
Feb 4 2007, 05:27 PM
alright you butt thread pirates......
back on topic.
so pulled all tin off motor. pulled rocker arms/pushrods/etc....
ready for pulling the heads next free weekend.
r_towle
Feb 4 2007, 05:31 PM
nice stains...
Rich
Aaron Cox
Feb 4 2007, 05:33 PM
yeah... last tranny leaked real bad...
new shorty gear one leaks a little too
r_towle
Feb 4 2007, 05:41 PM
liquid gasket...at the autoparts store, made for aluminum...works like a charm...
BTDT same leak.
Rich
soloracer
Feb 4 2007, 06:13 PM
Aaron: That doesn't look like a flat six in the back of that pickup. Do something about that why don't you?
Aaron Cox
Feb 4 2007, 06:17 PM
QUOTE(soloracer @ Feb 4 2007, 04:13 PM)
my checkbook is a few digits short of that....
but my truck has had a six back there LOL
Brando
Feb 4 2007, 07:30 PM
I dunnos what yew were dewin, but when I put cases and transmissions back together they doan leak
QUOTE(Aaron Cox @ Feb 4 2007, 03:33 PM)
Aaron Cox
Feb 4 2007, 09:20 PM
QUOTE(Brando @ Feb 4 2007, 05:30 PM)
off my back monkey!
thomas/joe/I put it together... all new. it leaks a tad. its 30 years old....
Crazyhippy
Feb 4 2007, 09:31 PM
While it's apart.... how about a turbo and watercooling??? Oh and Dual Overhead cams, and Fool Injection, and no more oil leaks (besides my damn speedo drive), and....
Now's the time....
John
Feb 4 2007, 10:52 PM
Aaron, nice engine lid.
Is that really a current pic? The grass is that green? You suck!
Aaron Cox
Feb 4 2007, 11:02 PM
i sweat 5 lbs yesterday and today... felt 90 ish outside today.....
plenty warm....
the lid is "eh...pretty good". not perfect. but looks ok. thanks for the props.
now find me some pistons
Type 4 Unleashed
Feb 5 2007, 12:25 AM
Now your talkin Aaron.
Type 4 Unleashed
Feb 5 2007, 12:37 AM
QUOTE(Aaron Cox @ Feb 4 2007, 03:27 PM)
back on topic.
ready for pulling the heads next free weekend, & splitting the case for a stroker crank & new rods & a killer cam.
Now, your really talkin.
Aaron Cox
Feb 5 2007, 12:38 AM
ROFLMAO
you kill me bro!
Type 4 Unleashed
Feb 5 2007, 12:57 AM
I have a question
Why did you split your fan shroud ?
Aaron Cox
Feb 5 2007, 12:58 AM
gotta take off the front piece to get access to the 4 nuts that attach it to the case
and to clean it
craig downs
Feb 5 2007, 01:05 AM
You can get to the nuts by just removing the fan
Type 4 Unleashed
Feb 5 2007, 01:09 AM
QUOTE(Aaron Cox @ Feb 4 2007, 10:58 PM)
and to clean it
No you don't, you just pull the 3 bolts on the fan, then pull the fan off, then you can get to the 4 housing bolts.
You can even leave the alt completely attached, you just loosen up the adjuster and the thru bolt on the bottom, so you can remove the fan belt, then remove the shroud & alt as one complete assembly. Installation is just reversed.
Aaron Cox
Feb 5 2007, 01:14 AM
yeah yeah... i know.
tin and shroud may get powdercoated while its apart.....
cleaned at a minimum.
