ClayPerrine
Feb 4 2007, 01:30 PM
Allan
Feb 4 2007, 01:39 PM
Got a silver center 150 mph speedo buried in there somewhere?
brp914
Feb 4 2007, 01:50 PM
Howzabouta steering rack splash guard?
How much per rear arm?
PORobinSCHE
Feb 4 2007, 03:20 PM
i am looking for a front swaybar, and a tach with clean glass.
thanks
Robin
rfuerst911sc
Feb 4 2007, 03:55 PM
In the 3rd picture from the top there are some rear shocks with springs that look like Koni's. How much and are they Koni's ?
KenH
Feb 4 2007, 04:00 PM
PM sent
Ken
ClayPerrine
Feb 4 2007, 06:08 PM
QUOTE(Headrage @ Feb 4 2007, 01:39 PM)
Yep. I don't know if the odo works, but it can be yours for $40.00 plus shipping.
QUOTE(brp914 @ Feb 4 2007, 01:50 PM)
No steering rack splash guards. Only have one, and it is for my car.
$75.00 plus shipping from 76054 for the arms.
QUOTE(PORobinSCHE @ Feb 4 2007, 03:20 PM)
thanks
Robin
What year?
QUOTE(rfuerst911sc @ Feb 4 2007, 03:55 PM)
They are not Konis, they are Mohollands. Yours free for the cost of shipping.
PORobinSCHE
Feb 4 2007, 07:39 PM
sway bar & tach for a 71 w/ a 1.7 litre
ClayPerrine
Feb 4 2007, 08:19 PM
QUOTE(PORobinSCHE @ Feb 4 2007, 07:39 PM)
No front sway bar. I can check on the silver center tach and let you know.
jd74914
Feb 4 2007, 08:31 PM
Are they still good?
ws91420
Feb 4 2007, 09:37 PM
Is that a p&c set in blue box? used? What bore?
tracks914
Feb 4 2007, 09:56 PM
Do you have any rear alignment shims in there??
Tx
ClayPerrine
Feb 4 2007, 10:06 PM
QUOTE(jd74914 @ Feb 4 2007, 08:31 PM)
I don't know about that set, but I have a pair that came off my car. They are still good.
QUOTE(ws91420 @ Feb 4 2007, 09:37 PM)
I think they are 2.0, but I have not checked them yet.
QUOTE(tracks914 @ Feb 4 2007, 09:56 PM)
Tx
I am keeping any alignment shims...
rjames
Feb 4 2007, 10:13 PM
Looks like you may have a set of left and right A-arms w/ the stock sway bar tabs on 'em. If so, how much $?
Thanks,
Robert
jr91472
Feb 5 2007, 07:39 AM
Interested in the engine case....what's its story?
ClayPerrine
Feb 5 2007, 12:18 PM
QUOTE(rjames @ Feb 4 2007, 10:13 PM)
Thanks,
Robert
I have 3 sets of A-arms with tabs. 2 with factory tabs, and one with the tab kits welded on.
$75.00 each for the A-arms with factory tabs. $65.00 each for the ones with the welded on tabs.
QUOTE(jr91472 @ Feb 5 2007, 07:39 AM)
Replacement case. It has one edge broken off of it on the bellhousing end. The break is cosmetic and would not affect the use of the case. I also have a 1.7L case sitting on the shelf that is missing the bearing dowel pins.
A&PGirl
Feb 5 2007, 01:31 PM
I noticed FI Parts in the mix. What do you have for a 1.8 FI and 2.0 FI?
Thanks
ClayPerrine
Feb 5 2007, 02:47 PM
QUOTE(A&PGirl @ Feb 5 2007, 01:31 PM)
Thanks
I don't have much of the 2.0 stuff, only one complete system. But that one goes with the GA case 2.0 that came out of my car, and it is spoken for.
I have a LOT of 1.8L stuff. I keep it because Betty's car is factory injected. If you need a particular part, I can probably get it for you.
What parts do you need for the 1.8L L-Jet?
A&PGirl
Feb 5 2007, 08:18 PM
Forgive my general ignorance on the L-Jet system
Does L-Jet come with fuel rails?
Does the L-Jet come with a throttle body like the D-Jet?
What is the condition of the Rear View Mirror?
Is there a cooling fan/impeller for a 1.7 in there?
Do you have any interior pieces?
Thanks
Feel free to correct my L-Jet ignorance
ClayPerrine
Feb 5 2007, 10:24 PM
QUOTE(A&PGirl @ Feb 5 2007, 08:18 PM)
Thanks
It should have the same fuel rails as the D-Jet. It has a throttle body that is almost the same, but it uses a different throttle switch.
The rear view mirror is in good shape, but not original. I have a couple of originals if that is what you want.
I have 4 good fans. do you need one?
Grelber
Feb 6 2007, 11:22 AM
Clay: Wes wants his stuff back.
ClayPerrine
Feb 6 2007, 01:33 PM
QUOTE(Grelber @ Feb 6 2007, 11:22 AM)
I didn't get it from Wes.. I am trying to keep up with him and Rich.
Grelber
Feb 6 2007, 07:48 PM
You'll need a BIG storage place, then.
Want to do a tech session on replacing the master cylinder? Saw mine dripping while up on Richard's lift.
I'm interested in the two top engine tin pieces if they're for a 2.0.
Are they cracked at all?
How much for both of them? How much for just the right side?
thanks,
-Sean
ClayPerrine
Feb 7 2007, 01:56 PM
QUOTE(Grelber @ Feb 6 2007, 07:48 PM)
Why don't you pick something harder?
Sure I can help. But we have Doug's car first in line.
ClayPerrine
QUOTE(STP @ Feb 6 2007, 08:24 PM)
thanks,
-Sean
I only have one set of 2.0 tin that is not cut for AC, and it is already sold.
G e o r g e
Feb 7 2007, 06:57 PM
Clay, do you have a right side uncut for a 1.7,1.8?
Engine tin is my topic
if so how much?
Grelber
Feb 7 2007, 08:45 PM
Changing the master cylinder isn't the problem. Trying to bleed the system by myself w/out a vacuum bottle is the problem.
ClayPerrine
Feb 7 2007, 08:56 PM
QUOTE(George H. @ Feb 7 2007, 06:57 PM)
if so how much?
Yep. I have it. $25.00 plus shipping from 76054.
ClayPerrine
Feb 7 2007, 08:57 PM
QUOTE(Grelber @ Feb 7 2007, 08:45 PM)
I have a pressure bleeder that makes short work of it. But it only has ATE super blue in it.
Grelber
Feb 7 2007, 09:26 PM
Might be a good time to change my fluid. But Richard will have the car for a bit longer.
A&PGirl
Feb 8 2007, 08:40 PM
If one of your original rear view mirrors isn't cracked, I wouldn't mind having one.
Thanks
ClayPerrine
Feb 9 2007, 11:26 PM
QUOTE(A&PGirl @ Feb 8 2007, 08:40 PM)
Thanks
Are you looking for an inside or outside mirror?
The outside mirror glass can be replaced.
If you need an inside one, I have them. I will have to take a look in "parts heaven" aka my attic to find one.
Trekkor
Feb 10 2007, 09:24 PM
Hi there...
Do you have a "D" first gear set?
Thanks
KT
MBowman325
Feb 11 2007, 12:09 AM
I ment to ask while I was there, will you have any extra flapper valves (motors, cables, J-tubes... think that's it) from this endeavor or are they all spoken for? Don (owns a yellow '72 for a long number of years) ran me down on the way over to Larry's, wound up going over to his place and talking with him for a while. In the process, I picked up some backdated 1.7 HE. Gonna see if I can't get some heat in the car.
Thanks!
A&PGirl
Feb 13 2007, 11:22 AM
It's the inside one one that needs to be replaced immediately. Where do you get the glass to replace the outside one? My Dad's outside mirror glass in shattered from some jerk slamming a door into it.
Thanks
ClayPerrine
Feb 13 2007, 02:29 PM
I have some flapper valves. I don't have any j-tubes or motors that work.
I have the mirror. Where do you want it sent? The glass on the outside ones is available from any glass shop. Just take them the mirror with the broken glass in it.
jr91472
Feb 13 2007, 05:28 PM
I got three J-tubes. One is fine and just needs cleaning up. The other two are both missing the tab that is spot welded on the side and allows you to bolt the j-tube to the side engine tin. You can probably fab a fix if you are handy with a welder.
All three are yours if you want them. Let me know.
QUOTE(MBowman325 @ Feb 10 2007, 10:09 PM)
Thanks!
Trekkor
Feb 14 2007, 01:29 AM
"D" gear?
KT
ClayPerrine
Feb 14 2007, 02:18 PM
QUOTE(jr91472 @ Feb 13 2007, 05:28 PM)
Thanks!
JR... are you through hijacking my for sale thread??
jr91472
Feb 14 2007, 03:30 PM
QUOTE(ClayPerrine @ Feb 14 2007, 12:18 PM)
Thanks!
ok, ok....I'll give you 10% of the proceeds from the sale of the J-tubes....
bobhasissues
Feb 14 2007, 05:02 PM
Thought I saw a Fuel Injection intake runner in one of the bins. I am looking for one OEM three bolt runner for a 914 2.0. I also need a Thermo Switch for the D-Jet, part # is 336 003 008 or 311 906 161C. If you have either, please contact me with your asking price(s). Thanks, Bob
ClayPerrine
Feb 15 2007, 04:09 PM
QUOTE(bobhasissues @ Feb 14 2007, 05:02 PM)
I only have one set of 2.0 intake runners, sorry. but I may have the thermo time switch. Let me check tonight when I pack stuff for shipping.
