QUOTE(dr914@autoatlanta.com @ Feb 6 2007, 11:35 AM)
QUOTE(sk8kat1 @ Feb 6 2007, 11:18 AM)
I am trying to remove heat exchangers and first they are a little hard to get to the nuts holding them on and second the studs that the heat exchangers attach to seem to have shifted so that the flat side of a few nuts are but up against the exchanger itself .
is this common ?.. I am kinda hesitant to start prying on them too much before i find out if there is any other suggestions on getting them off
I really feel for you! What a b..ch job! Over the years they get bumped, new studs are put in crooked and "mechanics" use 13mm nuts instead of the prescribed 12mm headed copper locking variety. The only thing to do is to use a narrow wall snap on socket and tap it on hoping it will straighten the stud and nut so you can remove it. Make sure first however that you remove the muffler and anything else attached to the heat exchanger so you can manipulate it for the ultimate clearance. Soak those nuts!!!!! You do not want to break a stud!!!!!
The original nuts were 13mm wrench size, not 12mm. The original nuts for the 2 litre engines had a substantial flange, as well, and they weren't lock nuts. The commonly used 12mm wrench size nuts are NOT copper, they're copper plated steel. Porsche never used locking nuts on the exhaust systems of air cooled cars, IME. The Cap'n
