QUOTE(rhodyguy @ Feb 7 2007, 10:24 AM)
in an earlier chassis, how does one adapt the wiring utilizing the engine relay board?
k
I took the wire where it goes to the fuel pump and pulled it back to the point where the harness turns into the tunnel. Then I fed it through into the tunnel. Once in the tunnel with the rest of the wires, I spliced in a new wire the same gauge as the existing wire. Then I ran it forward, following the harness routing. With the tank out, I was able to add the wire under the tank at the same location as the master cylinder wiring. The ground was run as a brown wire back to the ground point by the relay board.
When I move a fuel pump, I put it on the left side of the steering shaft. The reason for this is I assume the engineers who decided to move the pump up front for 75 knew a little bit more that I do about how to do it right.
Then I put in a carburetor fuel filter on the SUCTION side of the pump. This catches the shit that the filter screen in the tank is supposed to catch and protects the pump. The filter here doesn't have to be a high pressure, fine mesh filter, because it is only protecting the pump. I then put another filter in the engine compartment on the pressure line going to the fuel rail. This protects the injectors from getting the fine particles that don't get filtered by the first filter. The second filter needs changing more often, so I made it easily accessable.
I also run 2 hard lines from the pump back to the lower right corner of the fuel tank well. One has a Y fitting in the end closest to the pump so I can feed the return line back in, and the other has the filter on it. Everything is tied down with padded line clamps.
Here's a picture of my fuel pump install. This was taken before I mounted the pump.
