r_towle
Feb 6 2007, 09:26 PM
OK,
Im thinking really hard about attending the Albaquerque shindig.
Here is the idea.
Im gonna build a super tall gear stack for the highway.
Im gonna bring the short stack in the trunk.
Swap it out once I get there....swap back for the ride home...
Am I high?
would it work?
If I go, you gotta get some more of the SOCAL contignent to go...
Rich
So.Cal.914
Feb 6 2007, 09:33 PM
Do you mean with the intermitent plate, pinion gear, the whole shootin match?
In that case I don't see why not, a drip pan, gear oil and some tools.
jd74914
Feb 6 2007, 09:35 PM
Rich, what do you consider a super tall gearset . . . like with an H gear?
Eric_Shea
Feb 6 2007, 09:36 PM
A-L-B-U-Q-U-E-R-Q-U-E
Why not just have a tall 5th in there? That's the only gear you'll use on the highway and you'll rarely use it on any track.
rick 918-S
Feb 6 2007, 10:13 PM
with an air cooled engine don't you want the RPM's up for cooling and best fuel milage? Can a 914 with stock gears run 70-90 MPH for a sustained period of time? If it ain't broke don't fix it. If anything just run a taller rear tire.
Aaron Cox
Feb 6 2007, 10:28 PM
flipped H/HA/HB will be too tall for a type 4 im guessing....
lets say you run at 80 mph the whole way....
you are better off bringing a PAIR of uber tall tires for the rear....
bondo
Feb 6 2007, 11:11 PM
Gonna swap out the ring gear too? (ring and pinion are a matched set!)
Aaron Cox
Feb 6 2007, 11:20 PM
more like ring pinion and intermediate plate and case
sounds like he would carry a whole nother tranny to make it a simple swap
914werke
Feb 6 2007, 11:34 PM
ok I say it.
Your
Crazyhippy
Feb 7 2007, 12:42 PM
QUOTE(Aaron Cox @ Feb 6 2007, 08:28 PM)
195/65's might look funny, but will get more more road covered per motor revolution (will throw the speedo off too)
"normal" wheels and tires in the trunk
BJH
Brando
Feb 7 2007, 12:59 PM
I amend the taller rear tires suggestion. Otherwise, clear out the passenger's seat for stow-away room of that spare trans. Changing gearstacks at an event is not very fun, when you could either change the whole tranny in less time or swap rear tires in even less time.
ClayPerrine
Feb 7 2007, 01:06 PM
I can change out the gearstack, provided it has the exact same matching numbers on the pinion gear as the one that comes out. Otherwise the ring and pinion is gonna howl like Miles' goat when she sees him unzipping!
I would suggest that you put in a tall 5th to use on the highway, and don't screw with it at the event!
