41ghost
Feb 9 2007, 01:01 PM
doe's anyone have a good idea on how much of a temp. increase 96mm pistons give to the engine and oil temp. trying to get a close estimate so i can get a correct size oil cooler for the full flow system. thanks
Bleyseng
Feb 9 2007, 03:16 PM
0F
41ghost
Feb 9 2007, 03:35 PM
QUOTE(Bleyseng @ Feb 9 2007, 02:16 PM)
0F
of ? are you asking a question , or does this mean something
914nerd
Feb 9 2007, 03:37 PM
I would be inclined to think that he is saying that there is an increase of 0 degrees (F). I have a 1.8 with 96s and it has no trouble with just the stock cooler, so I am inclined to agree that it makes very little difference.
41ghost
Feb 9 2007, 03:43 PM
i was wondering if it added any . but i'm building a 2270, almost done. jake has it configured with a full flow oil system which requires a relocated oil filter and a seperatt oil cooler, the people i'm looking to get a oil cooler want to know the temp. i'm going to be cooling, and i have hand no reply from aircooled tech. on this matter so i'm just trying to see if other may know.
Crazyhippy
Feb 9 2007, 04:20 PM
I'd ask Jake...
SLITS
Feb 9 2007, 04:45 PM
Your oil temps will run 180 F low and 240 F high after beating on it for a while .... that a good enough range?
Bleyseng
Feb 9 2007, 05:05 PM
You want the oil temps to run 200F to max 240F . Too low will keep the moisture (h2O) in it and you want it to boil out.
yes, Zero degrees.
A 2270 mild hp won't really need a oil cooler unless you are in AZ, Texas etc. A 2270 with more hp will.
41ghost
Feb 9 2007, 05:52 PM
what do you consider mild horsepower. this is suposed to come out to 165 to 180 hp.
41ghost
Feb 9 2007, 05:54 PM
also iv'e emailed and posted to ask jake with no reply, is everything ok down there?
Bleyseng
Feb 9 2007, 06:34 PM
QUOTE(41ghost @ Feb 9 2007, 03:52 PM)
install a oil cooler up front ala GT cars. It works great
