QUOTE(kwales @ Feb 9 2007, 04:50 PM)
NO NO AND HELL NO.
The 914 pump is a high pressure, high volume pump suited for the high pressures required for fuel injection and requires both a send and a return line as wel as a pressure regulator.
We went over this before for a carbed 914, and it is dangerous to say the least.
I would hate to see a decent 69 Ranchero go up in a ball of flame due to a high pressure pump squirting fuel out of a popped low pressure fuel hose. Heck, I've seen a 914 go up in flames and it is designed for the pump.
Yer car, yer fire, yer insurance. Sad way to learn that tires expand when the car and the ground is on fire and go POP!
Ken
i wont install unless im fully satisfied with the safe operation. i am replacing ALL soft hose with lined goodyear high pressure hose (much better than what vw oem calls for) the excess pessure or return line will be looped to the tank and free flow to releive dead headed or excess pressure. it will have adjustable regulator at carb OR possible at pump, whichever works best.
the fire ball carb conversions mentioned, did they have return line operational?
by the way in the tech articles under 914 info. it shows the steel fuel line conversion/front pump changeover. it doesnt show 3rd (or return hose on pump) hooked up, it just has the return pressure from engine teed into the fuel supply line to pump (pre-presurized line)
