QUOTE(JamesBernard @ Feb 10 2007, 12:04 AM)
Isnt it an essential part to the car?
wouldnt removing it cause something that i really wouldnt want, i.e. sticking, no control of throttle?
It's like Geoff says, here's a little more info. In the 2.0L 914 D-Jet, the throttle switch serves two major purposes. It tells the ECU when the throttle is closed (idle and overrun condition), and it tells the ECU when the throttle is being opened. There's a set of wipers that are connected to the throttle shaft that contact traces on a fixed board. When you open the throttle, a drag switch in the throttle turns on, and every time a wiper crosses a track (there are 20), a signal is sent to the ECU that causes a short injection pulse to be intermixed with the injection pulses already being sent. These extra injection pulses enrich the mixture and provide better acceleration.
When the switch is dirty and worn, you keep getting these extra injection pulses due to extra contactings while you're holding the throttle steady. By disconnecting the switch, you eliminate those extra pulses and the cause of bucking. You also make the car accelerate more sluggishly - but hey, it's a 914, who can tell?
If your bucking goes away when you disconnect the TPS, I would suggest opening the unit and cleaning the board with contact cleaner, then lubricating the trace areas with a contact lubricant like Stabilant 22.
