Really impressive build. Just curious, what are you doing for the intake side of the turbos? Does not look like there is alot of room for filters. Also, do you have any concern about the waste gates venting onto the turbos/into the intakes
The air filters will sit on either side of the intercooler. There is enough room to run some hose back up into the engine compartment. The wastegates are actually below the turbo inlets, and are pointed down, so no worries about that
I love the green on the motor and related parts
The customer wanted to be able to see all the powder coated bits, so the intercooler is mounted higher than we normally would mount one.
intercooler is a 12X24X3.5
trial fit to get ideas how to plumb things
