#1 what is the psi range of a stock 914 high pressure/high volumn pump with out regulator (UNREGULATED pressure)
#2 has anyone "adjusted" the regulator. it apears adjustable, if so what ranges will it cover (adjust down to).
#3 on the fuel pump relocation artical (installing ss replacement lines) in 914 info. why does the "fuel return" line from the engine "y" back into the "fuel supply line"? (2 different flow directions)
#4 where is the 3rd line on the pump (fuel return) going, its covered on the picture
