QUOTE(fall-apart-dave @ Feb 19 2007, 03:12 AM)
QUOTE(Grelber @ Feb 18 2007, 05:54 PM)
So if I were to go for 40's (Dell or IDF) what would you guys reccomend I jet and vent at? 32mm vents with what jets (never even opened a carb before so this'll be fun!)
Like the others have said, consider your long term plans for the motor so you only have to buy carbs once.
FWIW: My Dell 40's are setup:
idles 55
main 140
air 180
emu .2
pump jet 35
I also replaced my 050 dizzy with a stock 009 and a Crane Allen Fireball ignition. This allowed me to connect the vac advance to the carb and has had the
most dramatic impact on performance than anything else I have done. I hear Mallory's are even better.
Also, if you go with Dell's, familiarize yourself with CB Performance. They have been the only place I have found that consistently carries parts for Dells.
good luck and keep us posted.
