i got some early 911 rear arms, and proceeded to pull the hubs out and get th ebrakes off of them yesterday.
my question: what is the minimal 'pad' thickness allowed? and where is it measured from?
AA
So.Cal.914
Feb 18 2007, 11:37 AM
I don't think there would be a minimum Aaron considering you only apply
it when parked. Have them arched to fit the drums and there done.
Eric_Shea
Feb 18 2007, 02:57 PM
I searched the entire factory manual for your year brakes. Nada. There is one errant description way in the back of the brake section stating the handbrake lining is 25mm (or .98"). NO POSSIBLE WAY. They "may" have been 7-8mm when new.
Most I've seen look to be between 4-6mm.
Paul is correct. If there's lining on there, you're probably in good shape. You don't have to do any arching though...
736conver
Feb 18 2007, 04:00 PM
QUOTE(Eric_Shea @ Feb 18 2007, 02:57 PM)
Thats width your seeing Eric. The minimum lining thickness is 2mm.
Aaron Cox
Feb 18 2007, 04:24 PM
cool. i think i am good
this will be a spring break project i believe.... (3 weeks away)
Eric_Shea
Feb 18 2007, 06:07 PM
They list the width at 32.0mm (1.26") - Section T page 5.
Eric_Shea
Feb 18 2007, 06:10 PM
Ooooooooops... correct Sir. It's listed as an update for the 1970 MY. - Section ST (supplements group T Tires, Brakes and Wheels) page 24.
