I would like to install an EGT gauge on my 2.0. From what I've read, it seems most probes go within 6 inches of the exhaust valves on the header. I don't want to tap a hole in my stainless heat exchagers. My thoughts were to put the probe on the exhaust tubing that connects to the heat exchangers. I realize the exhaust is most likely cooler at that point, but should work OK??
Do they make an EGT probe that is a clamp on type so I could connect it closer to the heads?
