QUOTE(Pat Garvey @ Feb 19 2007, 11:16 PM)
QUOTE(mrgreenjeans @ Feb 19 2007, 10:07 PM)
QUOTE(Pat Garvey @ Feb 19 2007, 10:56 PM)
I have no plans for a CW event this year & need tires. My CW tires are mounted on painted (gorgeous) steel wheels and are 28 years old (2000 miles). I'll replace these separately with somehing from Cocker.
Question here is - what should I put on my deep dish chromies for street driving? Last set on them was A008R's, and they were fantastic.
So, I'm looking for input since, as you can see, I've not bought tires in a while.
These are my considerations:
Wear - don't care.
Stickiness - care a lot.
Confidence value - must be high.
Autocross - maybe, but probably not. Spirited driving = lots.
Looks - not really important.
So, what would the shoes recommend
Just bought a set of Bridgestones in a semi perf. tire for a couple of my Audis, and I LOVE them. This is a much bigger and heavier car tho....200 turbo and 200 turbo Quattro.
On my teener, I am driving on a Firestone Firehawk that's about 10 years old and still VERY sticky for semi-spirited, but non-DE use.
On another Audi, an old 4000S I have a set of Yokohama 550's and I could not believe the transformation that made in the cars tossability on fast, curvy, road use. Had a totally different line thru the off camber , decreasing radius sweepers than my friends 944 or his 914- 2.0, but I tell you, they GRIP at 9/10s driving. Yoko's are all very good ....and quiet too. Wear like crap.......
Summing it up....anything that seems like it has little to no tread blocks, with long open grooves running with the pattern, in today's modern Japanese technology, has my first look. There is some VERY good stuff out there. Even Dunlop and Michelin are coming around to look better every year.
Good Luck !!!!
mrgreenjeans
I put a set of Dunlo SP4000's on my wife's Passat 2 years ago. Don't think they'll wear well, but boy do they grip "on that car". Little noisy, but I don't play the radio in the 914, so who cares? Input?
My M030 944 NA came with Dumb-flops , back in 84. Granted there have been leaps and bounds in technology since then, but have the good ol boys over Euro way, come to grips with it all , or are they still following the line like Goodyear does here ?
So....am a little sour in the mouth after THAT experience. Gave a whole new meaning to the term scared sh*tless, when finding they would not grip on turn in, nor dispense with water, nor brake well. Kind of like riding on hockey pucks....made in 1929. Will not go in that direction for a long while-----
Meanwhile, back to the subject at hand: you LIKE your Dunlops on the Passat ---and that's a very good handling car. Sweet in fact. Almost makes a guy grimace a little crawling into the teener, after riding in one.....( oh, but they are still so sweet and lovable
) SOOOO, I digress....., if they have now found a compound in which to make a tire that seems to emit just a small amount of noise, compared to the elephants wailing I heard at speeds above 50 mph in the 44, then maybe they have also found a tread compound that ACTUALLY likes to get up close and personal with an asphalt surface without repelling said vehicle.
This is good.
Best wishes on the buy of your tire choice. Now , you only have to worry about the tire mounting procedure, and the 16 year old tire manager's son who thinks he knows how to operate the machine after Unca' Bucky's showed him how.....
mrgreenjeans
