r_towle
Feb 20 2007, 02:35 PM
Are you interested and capable (water jet) of making some exhaust flanges?
Rich
Engman
Feb 20 2007, 04:39 PM
No water jet - but I can and do laser stuff. Exhaust flanges? 2.0 or 1.7?
M
r_towle
Feb 20 2007, 05:48 PM
seems to be a market for both.
Me, I want 1.7, four sets. that would be eight flanges.
Also one set of 2.0 liter.
All stainless if possible.
If you are game, PM me , I would be happy to start a group buy thread to see how many people are really interested.
It seems easy enough once you get the dimensions..
Rich
ChrisFoley
Feb 21 2007, 07:12 AM
It takes a pretty big laser to cut 1/4" stainless. Waterjet would be better IMO. Last time I tried to drum up interest in this it fell flat when the price estimates were posted. How much would you be willing to pay for each Rich?
Engman
Feb 21 2007, 08:17 AM
I cut SS all the time - up to 1/2". BIG laser.
M
r_towle
Feb 21 2007, 10:37 AM
I cant draw and deliver the part in a CAD drawing or Gcode...
I can do it in pencil...
I can scan that.
It might be importable into a decent program...
I think as a standard part from Engman, its a good idea, provided its simple, cost effective, and there are enough people that really need them initially to cover the costs of the initial setup time.
Rich
type11969
Feb 21 2007, 11:33 AM
Rich - If you need someone to turn your drawing into a CAD file, I can do it no problem. Send me dimensions, I'll make a 3d model and a drawing for it in solidworks.
-Chris
Engman
Feb 21 2007, 11:52 AM
Pencil is fine - we will work it out.
M
r_towle
Feb 21 2007, 11:53 AM
gimme a few days...
Rich
brer
Feb 21 2007, 11:54 AM
whats a laser like that cost to run an hour?
I use a small one for model making and it aint exactly dirt cheap when you factor in purchase price/ per hour cost.
Engman
Feb 21 2007, 11:58 AM
Depends on the laser and if ya get the employee discount.
One laser we have will do 600 1/16" holes in 16g in one minute.
I did not belive it until I saw it perform.
M
ClayPerrine
Feb 21 2007, 12:03 PM
QUOTE(Engman @ Feb 21 2007, 11:58 AM)
M
You need to make a video of this.. it would be cool to watch.
On Topic, can you make flanges for the cylinder head end of a heat exchanger? The ones on the 2 sets I have are just little loops of stainless that seem to pull loose from the tubes. I think a for real flange would be better than what is currently there.
r_towle
Feb 21 2007, 12:09 PM
QUOTE(ClayPerrine @ Feb 21 2007, 01:03 PM)
M
Those are stub pipes, and CFR along with quite a few others sell them already made up.
Rich
ClayPerrine
Feb 21 2007, 12:17 PM
QUOTE(r_towle @ Feb 21 2007, 12:09 PM)
M
Rich
Stub pipes wont work on a heat exchanger. It needs a flange to replace the loops.
The flange would have to be welded on.
r_towle
Feb 21 2007, 12:36 PM
QUOTE(ClayPerrine @ Feb 21 2007, 01:17 PM)
M
Rich
Stub pipes work on heat exchangers if you cut the end of the heat exchanger down, and weld on the flange the CFR sells to mate to the stub pipes.
I will be doing this in the next month or so...overall is makes removing the HE much easier, cause you can leave the head studs alone.
I think that CFR's stub pipes use heavier guage for that loop thing.
a flange would not really work there, it would need to be stepped down, and custom mated to the head for each one, unless you open up that mating surface of the head to create a larger flat spot.
then you will hit the head studs...there really is not alot of room there.
Think about cutting the HE down and welding on the flange, I personally think that would be alot easier, and provides benefit in the long run...
I would love to be able to simply remove my HE when its time to adjust the valves...
Rich
Chris Pincetich
Feb 21 2007, 01:34 PM
Rich - I am getting ready to swap SS HEs for a header with stub pipes and have been thinking EXACTLY what you described = cut down the solid HE exhaust tubes and weld on a flange to mate them to my stub pipes. Makes for easy on/off and winter SWAP for heat! I hope to accomplish this over the summer
ChrisFoley
Feb 21 2007, 04:37 PM
A small problem with that idea is the HE's do not have 4" of straight tube from the port face. That's the length of all the stub pipes I've seen. The HE's might have to be lowered for it to work.
Aaron Cox
Feb 21 2007, 04:39 PM
or make reaaaaally short stub pipes with captive nuts/threads so you only need one socket and no wrench to hold the top side.
alpha434
Feb 21 2007, 07:47 PM
G01 x.0 y.0
G01 x.2 y.0
G02 x2.25 y-.025 I.5
G01 x2.75 y-0.75
G02 x2.75 y-1.25 I.5
Wait. What are the dimensions again?
Engman
Feb 21 2007, 07:55 PM
Thats old school stuff there....
I do not miss the old days...
M
solex
Mar 24 2007, 10:07 AM
Mark,
Any news on the flange?
Thanks,
Dan
Engman
Mar 24 2007, 12:58 PM
Schefuled to make them next week - - laser time.
Engman
Mar 30 2007, 01:58 PM
Just got them - I can ship up to four for $4.55 - part is $11.50 each.
Will post pics later.
M
Engman
Mar 30 2007, 03:49 PM
Top is the .25 thick ss piece
Bottom is the muffler gasket (shown for camparison - not included)
Allan
Mar 30 2007, 04:09 PM
Wow, that's nice...
