QUOTE(meador36 @ Feb 21 2007, 09:02 AM)
I've never pulled a motor out before just fixed everything with the motor in the vechile. Sounds like alot of work.
Not really.
Stand by the car, pick a side...
Look down..
All the wiring on the drivers side gets unplugged, but the FI wiring harness stays with the motor.
On the passenger side..take out battery, unbolt computer and lay that on the motor
Under car, remove CV joints (probably the part that takes the longest...and that is less than 5 min per joint.)
Now, elec off the starter, fuel lines, clutch and speedo cables, shifter rod.
Then four bolts, and your motor and trans are out.
From there, you really want to remove the tin, clean the motor out of all the years of crap..it will run cooler, and run better when you are done.
Rich
