ahdoman
Feb 21 2007, 03:52 PM
Anybody got a good way to remove paint overspray from seals w/o damaging the rubber? Not my bad - previous owner so paint has been there awhile.
Johny Blackstain
Feb 21 2007, 03:57 PM
I know this might sound a bit absurd however I'm quite serious... try "creamy" peanut butter. Does wonders for removing wax from rubber & black plastic. Can't hurt the seals/rubber/etc...
Spoke
Feb 21 2007, 04:18 PM
I've used both acetone and paint stripper.
The acetone I've dampened a cloth and rubbed until the paint released.
I think paint stripper uses acetone along with some jell stuff to keep the active ingredients from evaporating too fast.
Spoke
jasons
Feb 21 2007, 04:27 PM
Lacquer thinner? Test and make sure it doesn't eat the rubber. Whatever you use wear rubber gloves!
markb
Feb 21 2007, 04:42 PM
If you can remove them from the car, soak them in Simple Green. This will make the paint come right off, and it rejuvenates the rubber nicely, too.
r_towle
Feb 21 2007, 04:48 PM
or goof off and steel wool.
Rich
Porsche Rescue
Feb 21 2007, 05:08 PM
I have used lacquer thinner and fine steel wool many times with great results. Frankly, I usually didn't use gloves but probably should have.
Goof Off is also a great product, but I'm not sure it will work on all paints.
Aaron Cox
Feb 21 2007, 05:09 PM
QUOTE(markb @ Feb 21 2007, 02:42 PM)
i send my seals to a health spa when they need rejuvenation
vertigo
Feb 22 2007, 09:35 AM
I use the cheap autozone carb cleaner (1.19/can). Have no idea if it is actually good for carburator, but for removing paint it is great.
