nick mironov
Feb 21 2007, 07:55 PM
I searched and read the topics I found on the subject. The topics mostly describe how the headlight motor system works. None describe what the typical problem is and how to fix it.
In my case, (1975) the headlight motor itself works. The right side headlight always comes up, but recently does not always go down. Is there a problem with the motor, a relay, something else? There is no obvious adjustment.
Nick
boxstr
Feb 21 2007, 07:57 PM
Remove the realy on that side and reinstall, spray a little wd 40 in the socket holes.
CCLINUPANDDOWN
URY914
Feb 21 2007, 07:58 PM
Spray it with some cold water.
Chris Pincetich
Feb 21 2007, 08:04 PM
Your trusty Haynes manual shows how to lower it in a jam. There is a non-obvious knob on the back of the motor, turn the knob A LOT and the light raises or lowers. The first time(s) I did it, I accidently unscrewed the knob...it works going either way.
Swap the relays side to side and see if that identifies a bad relay.
Johny Blackstain
Feb 22 2007, 11:28 AM
Disconnect the battery so you don't fry anything. When you turn the knob, check to see the "eye lids" aren't jamming up against the bottoms of the plastic headlight surrounds, (held on by 3 screws). You should also check for bad fuses, loose wires, grounds/shorts, etc...
ClayPerrine
Feb 22 2007, 12:33 PM
Also try tapping on the motor with a screwdriver handle. There are wiper contacts in the motor, and they get dirty or corroded over time. If the contact is open, the headlight won't go down. Tapping on the motor may get the contact to reconnect, and the light will go down.
If that is the case, the easiest way to fix it is to replace the headlight motor assembly.
Project 6
Feb 22 2007, 12:51 PM
If after four hours and it is still in that condition, call a doctor.
ClayPerrine
Feb 22 2007, 01:32 PM
QUOTE(Bass Fisher @ Feb 22 2007, 12:51 PM)
You watch WAY too many commercials on TV.
Rand
Feb 22 2007, 01:53 PM
Any results Nick?
Swap the relays from side to side. If the problem trades sides, you have a bad relay.
If they both work, it was a dirty connection at the relay contacts.
If the right is still bad then it's the motor or wiring on that side.
MJHanna
Feb 22 2007, 03:01 PM
I just took a hammer to mine. It stays down real nice now.
